Panasonic Problem I own a Panasonic TV. Model # CT-32SL13G. I was watching it right before I went ot work. About an hour and a half later, I came home and tried to turn the TV on, but nothing happened. I tried unplugging it and plugging it back in to the wall, but still nothing happened. I then tried plugging it into a different outlet and nothing happened. The light doesn't turn on, it's like it isn't even plugged in. Do you have any suggestions?
  • 1 more comment
  • sharonmue21 Nov 04, 2008
    I just had the exact same thing happen to my 5 year old CT32SL13G.
    Did replacing the fuse fix the issue?
    Please advise.
    Thanks so much.
    Sharon
  • Anonymous Mar 14, 2009
    SAME THING REPLACED FUSE WORKED FOR AWHILE AND THEN IT WENT OUT. REPLACE FUSE AGAIN AND NOW IT WONT TURN ON AT ALL
  • bfoothorap Apr 04, 2009
    My Panasonic CT332sl13 TV will not come on either
    I cannot locate any fuse
  • 40 Answers
Replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Posted on Jul 19, 2008
Panasonic viera screen
Sounds like a panel fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD TV panel is given. You can compare it to that of your TV's, and can make sure.
Apr 11, 2014 | Televison & Video
I was watching tv and suddenly the picture went off.Now the red power light is flashing and I cannot get a picture.model panasonic viera th42pd60u
Tries tv unplug,replug it back like about an hour later,by for the tv resetting itself back for factory setting.Now tv should be working,if still have the same problems.The tv have power supply board problems and causes.That the board,where the power a/c cord plug into it.Tries website like Ebay.com to buy a refurbish power supply board for the replacement.
Feb 16, 2011 | Panasonic TH-42PD60U Television
I bought a panasonic model ct-27g14a tv from a thrift store when i got it home i found that the parental lock was activated and did'nt have the code.
Sorry,u must have it orignal codes,there noway to unlock secrect personal codes.U push the channels + or - buttons manual controls couples times.Might get in the tv input.Hook up,use it with DVD player can watch DVD Disc thought.Sorry, you probally only can watch shows rated Y for children only.
Jun 02, 2010 | Panasonic CT-27G14 27" TV
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
Panasonic 27'' tube television
There are some components in the vertical deflection circuit area that are failing. An experienced TV service man should be able to troubleshoot and repair this for you. It could take several hours of labour cost.
Jerry G.
Apr 26, 2009 | Panasonic CT-36D12D 36" TV
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
How to change the fuse on a panasonic CT-32SL13G What kind of fuse is it and where is it located
Apr 04, 2009 | Panasonic CT-32SL13 32" TV
Panasonic CT-32SL14 flat screen tv stopped working
We played Wii sports and fit for few hours than tv started to flicker and change colors to green and black and white. We shut down Wii and not TV screen doesn't show any picture. The power is there and the sound... but the screen is just blue. Any one experienced anything similar?
May 20, 2008 | Panasonic CT-32SL14 32" TV
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
