Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Canon ir300 e602-0001
Copier displays grey screen that says e602-0001 and wont function. cant clear screen. What is this? Help
    Sniper:
  • 57 Answers
You have a faulty hard disk. Replace hard disk and you have to re install software back in machine. Unless this is done the machine will not work.
Posted on Aug 03, 2008
E000003-0000
good morning sir, my ir machine is 3300 the problem is showing to my machine is E000003-0000 please suggest me answer
Thanks
Apr 21, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
E000000-0001
Enter in service mode and clear this error: press aditional functions then press number 2 and 8 together and press again aditional function. Screen should display copier, on the screen press: copier/function/clear/err and then ok. Unplug the machine and wait 5 second then restart, if problem persist replace fixing heater
Apr 14, 2014 | Canon ImageRunner 4570 | IR4570 |
My canon ir 3300 touch screen panal not working.but matchin is start.only power light(green)glowing.
sol1) In service mode copier- function- clear- error. (Service mode can be accessed by pressing additional functions- 2-8-additional functions in quick succession).This should help
OR
Sol 2) Open the display unit of your copier and take it for dry soldering.
Note:- expert help may be required for step 2. don't try yourself.
Oct 30, 2013 | Canon Ir 3300 B/w Copier image Runner...
ERROR CODE e000001-00010
Thsi is an error code dealing with temperature of the fuser assembly. . Try resetting the error code by going into service mode: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. You should be in service mode. If not press the reset key serveral times to make sure everything is reset and try getting into service mode again. Press the " COPIER " button on the display and the screen changes. Press the " FUNCTION " key across the top of the display and then " CLEAR " then " ERR " and finally " OK ." You have cleared the error out of the copiers memory. Turn off the copier waits a few seconds then power back on. If the error comes back then you have to have the fuser assembly either rebuilt or totally replaced. Good Luck.
Jul 31, 2012 | Canon imageRUNNER 5000 Copier
How do I reset the admin password for a Canon iPF605?
The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additionalfunctions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Jun 29, 2012 | Canon Office Equipment & Supplies
Canon ImageRunner 3300 G
The IR service manual says E602 means the harddrive is toast.A little tough to fix on an IR300 without the canon service tool on a laptop.It Fundamentally means you have to reimage the copiers hard drive with a new image.They don't call it imaging, they call it downloading a new OS, which must be downloaded from Canon.A trained IR service tech should be able to do it in about an hour.Good Luck
Apr 07, 2009 | Canon imageRUNNER 400S Copier
Fiery of Canon IR300-405 asking Auth Code
I have experienced this before but seem to remember I had to format and upgrade the Fiery software using the special software tool. Everything worked fine then. Sorry I can be more precicse but it was a while ago.
Mar 23, 2009 | Canon Office Equipment & Supplies
Error code E000019-0000
Hi this is only indicating a dirty waste toner bottle neck.
It is easy to solve.
Take a star screwdriver,remove the one screw of the left lower panel.You will find the panel at the left-lower side of the machine,the side were you have to open to remove paper jams on the fixing side of the machine.
After removing that panel,remove the bottle remove the toner inside the bottle clean the NECK of the bottle inside and outside and put the bottle back in it's place.Put the panel back and switch machine on and off.
THIS WORKS ALWAYS
Jan 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Canon ir C3100 Admin Password
Hello skunkel,
Yes, I believe I can help you. Hopefully these previous admin person did not go nuts with the security thing. But I can help you either way. The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additional functions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Jul 30, 2008 | Canon imageRunner C3100 Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
583 people viewed this question
old marine
old marine
