Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer timer
I just replace old timer with new timer and now no water is coming in, need help.
  • 5 more comments
  • jedi7908 Jul 18, 2008
    I already checked connections.
    it is laundry washer not dishwasher
    where is the circuit, u mean circuit breaker?
    before my timer went bad, water was coming normal and changes were made in the hose since. Only new timer was replaced.
  • jedi7908 Jul 22, 2008
    I did check the connections. I wonder there may be a problem at water pump. how do I check power is going to the pump. Thanks
    where is the water mixing valve, how can I check it. Thanks.
    I checked water mixing valve it is OK, can it be the timer again. They may gave me the bad one again.
  • 868 Answers
During all the check points you may have overlooked a wire problem most likely at the water valve.Do you have "no-burst" water hoses? If so then your next check is to pull one of the hoses loose , turn on the water and make sure its flowing through.If your not using this type hose try putting your old timer back in and if its your timer at fault the water will fill up .
Posted on Jul 22, 2008
  • Archie Ferrarini
    Archie Ferrarini Jul 22, 2008
    Ahaaa ! ! I see the mention of flood safe device (also known as no- burst).Pull one hose off and see if water goes through it.
  • Archie Ferrarini
    Archie Ferrarini Jul 26, 2008
    Why did you change the Timer is my first Question?
    this is a picture of valve (water)
  • Whirlpool Master
  • 19,396 Answers
Yep the Dutchman was right, if you did the replacement with power off and did not touch anything else check the connection, remove panel and mount it back, it is the most obvious.
Posted on Jul 18, 2008
  • Ginko
    Ginko Jul 22, 2008
    the water mixing valve must be the inlet valve.
  • 818 Answers
Following the instructions : " I turned off the water,
removed old hose connectors & Install the end of the connector
with the flood safe device at the shut off valve.
Install the other end of the connector to washing machine, and tighten
nuts with a wrench.
Slowly turn on water at the shut off valve to full open position.
Check for leaks.”
Ok, I did all that.
    Master:
  • 848 Answers
The circuit might have been shorted try to check it...... also install filter to drain more water in .......
  • 6,487 Answers
Set the control to the start position...next, remove the lower access cover and then locate the valve your water line is connected to. Now remove the electrical wiring plug from the valve and with a voltage meter, stick your two probes into the respective terminals on the plug you just removed from the dishwasher water valve. Now turn on the dishwasher and wait. It may take 1-3 minutes before the voltage appears.
Hope that helps.........
  • 487 Answers
Please check the wiring as you might have not hooked up the connectors for the water valve.
  • 2 more comments
  • eric bosman
    eric bosman Jul 19, 2008
    check your water level switch too which is on the same contral board ( part number3366845 ) or the wire towards your water mixing valve is lose.
  • eric bosman
    eric bosman Jul 22, 2008
    water mixing valve is number 18 on this drawing
    You might also try the water level switch.
    You can test that by conecting the 2 poles and so by-passing the switch. You might have a bad level switch which will disconnect power to the inlet valves.Number 12 on the same drawing.
    And the water mixing valve is not an inlet valve
  • eric bosman
    it can not be the water pump as that is only used for draining
  • eric bosman
    eric bosman Jul 23, 2008
    yes it can be the timer again.
    Make sure that you get the timer for the right machine as there are about 12 types of the LSQ9549L (check HERE)
    It also has i think 6 different timers. Make sure you get the right one.
Washer fills with water but the timer is not moving
timer sticking if you can get at it spray the timer with wd40 penatrating spray or simmilar if that doesent work it the timer clock probably cheaper to buy a new washer than have this replaced hope this helps ivan
Sep 25, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine stops half way through the cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 30, 2009 | Whirlpool AWM6100 Front Load Washer
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
Portable Whirpool washer, floods the floor when in use
dose it stop flooding when you stop the timer or turn off the water.if timer your presure switch hose has come off.have to empty washer to reinstall because water in tube gives false reading.if when you turn off water its your water level switch.God bless,tom
Jan 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool 6th Sense AWM8123/1 error code FH
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.thank u....please rate it
Nov 28, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool duet washer f-27 code error
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer wont spin
the whirlpool washer fills up with water and does nothing. I have replaced the lid switch and timer and still have the same problem. Please help me. It is only six months old
Apr 10, 2008 | Washing Machines
Washing Machine won't empty water during the cycle
does the timer advance by itself? if not the problem is your timer not advancing through the cycles. if timer does advance then being 14 1/2 years old it could be the motor. start the washer and mark the beggining where the timer starts. whatch it to see if it moves if not then you need to replace your timer
Jan 30, 2007 | Whirlpool LSR9434PT Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
