Retail plus external not found by win 8
ok i know the answer.
500gb what, 2.5" 3.5" what? both have different startup currents
what USB port, USB2, USB3, usb 3c what?
Your drive is seen as removable for sure,..
but you failed to say what you have there.
USB external, ?
Estat ? port like I use that allows even hot switching.
what?
answer 1:
The USB drive will need to be formatted.
if it fails then that means.
1: HDD bad.
2: not using a power pack at the HDD case, jack at least 1 amp rated , do not run any HDD using the USB as power or it will fail.
the startup currents off all HDD are more that EVEN USB3 can handle. but USB3c might. C is for charging Cell phones .
3c is only seen on newer PC.s.
3: the HDD enclosure needs special USB driver, did you ask the maker this? whos is it. the maker was not disclosed by you.
answer 2: Esata. ill wait till later if this interface is used, like mine
i have 3TB drive on mine, and never fails. for for 5 years. 3.5"
The OS talks to your USB drive. external
if the drive busy line is true all the time the OS can not know why
at all ,how can it? (impossible)
so it tells you insert it, that is how this works.
brutal simple it is,
The busy line is true , is due many CAUSES.
1: NO 2-AMP POWER PACK THERE, AND CAN NOT GO OVER THE STARTUP CURRENT OF 4.5AMPS.
2: Drive bad, cables bad, there, usb chip bad there. usb cable bad there. or usb port dead. on pc.
3: usd drivers missing. to run this usb chip in the box.
4: system infections?
ive done this VAST times, in all ways from sunday
if I knew what you had there , ( i cant see it)
id answer shorter.
my pro grade Phantom drive runs a 2amp pack, and fails hard less.
id bet the power pack is missing or WRONG.
