Microsoft Windows XP Professional With Servise Pack 2  for PC
Problem for Microsoft Windows XP Professional With Servise Pack 2...
Forgot admin. passsword
By tured1224 on Jul 18, 2008
I put a password on my account(admin. password) so no one can log on to my files, etc....., but i forgot the password and now i can't change anything on the computer. I bought another computer, so i didn't really think i would have any use for the comp. in the living room, but i want to share my pictures, music, etc... but i cabn't because i can't sign in as the admin. No i didn't make a password disk either. How dumb, right? Is there anything you guiys can do to help me. please?
Solution #1
posted on Apr 21, 2009
Somewhat Helpful)
Alexis xy
Rank: Wiz
Rating: 78%, 228 votes
As far as I know , there are two main methods to solve the windows password problem as follows:
1st Method:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
Windows password reset software:
for example:Windows Password Reset.
The program will enable you to reset the password to blank with no -reformatting or installation. Do all the job for you automatically.
http://www.resetwindowspassword.com
Was this helpful?
Yes
No
Solution #2
posted on Dec 23, 2009
Not Rated)
zpowx2
Rank: Wiz
Rating: 78%, 27 votes
Free trial <a href="http://www.passwordunlocker.com/products/wpu.html"><strong>Windows Password Recovery</strong></a> Tool---<strong>Windows Password Unlocker</strong> is highly recommended </p>
<p >1.Download <strong>Windows Password Unlocker</strong> from Password Unlocker Official site </p>
<p >2.Decompress the Windows password unlocker and note that there is an .ISO image file. Burn the image file onto an blank CD with the burner freely supported by Password Unlocker. </p>
<p >3.Insert the newly created CD into the locked computer and re-boot it from the CD drive. </p>
<p >4.After launched the CD, a window pop up with all your account names(if you have several accounts) select one of the accounts that you have forgotten its password to reset it. Just one press, you have removed the password.
Comments:
Dec 24, 2009
- A few days ago, I had met the headache things that I had forgotten Windows login password. The login screen rejected my passwords. I was frustrated because there was very important data on my disk and I couldn't reinstall the OS. ............. However, I fortunately got to know the Windows Password Unlocker, which is a professional windows password recovery tool for us to reset windows 7 password instantly yet no data loss.
Was this helpful?
Yes
No
Solution #3
posted on Nov 02, 2009
Not Rated)
bombermanneo
Rank: Master
Rating: 98%, 14 votes
First Solution - If You Have An Account Which Is Not Named "Administrator"
With every new install on windows xp, an account named Administrator is created, this account is created automatically and has no password. So what you have to do? Well, if you haven't changed the password to this account, then you can restart your computer and reboot it in Safe Mode, pressing F8 on the setup screen, before the windows xp boot screen load. Then you choose the option, Boot in Safe Mode, if the Administrator account has no password (by default it doesn't) you'll now login to your windows xp account, once you do that, go to Control Panel, User Accounts and change the password you had on the your personal account to something you'll not forget this time. In short, you'll use the default account administrator to login into your personal account "Your Name" and change the password using the Administrator account. After changing your password, you reboot and log into your personal account with the password you chose. :-)
Second Solution - You Have Changed Your Previously Password
If you have changed the password of your personal Windows XP account, and you don't remember to what you did change the password to, and that's the reason why you cannot log into your account anymore.
You can use System Restore to restore your computer to a point where you did know your password, right before you change it. By default windows create Recover Points, to use this method you'll have to use our previously "Safe Mode" boot, in which you press F8 repeatedly on the BIOS screen. Once you are on the desktop, you click in Start>All Programs>Accessories>System Tools>System Restore. And choose a recover point date in which you were with your old password, click in restore.
Third Solution - Using "Windows Password Recovery Tool 3.0"
If you couldn't get back your account with those two steps above, or if your account on Windows XP is by default named Administrator and not your username, then you'll have to use some softwares to get back your password or reset the password on your windows xp.
In this module I'll be explaining how to reset your password using the Microsoft tool called "Windows Password Recovery Tool".
To acesses this tool you will reboot your computer normally, click over your username, and then press Enter, then you'll be prompted with an error message:
"Did you forget your password? You can click the "?" button to see your password hint. Or you can use your password reset disk. Please type your password again. Be sure to use the correct uppercase and lowercase letters."
You're going to click on "Use your Windows Password Recovery Tool 3.0".
In the Password Recovery Wizard dialog box, click Next.
Choose one user on list,and set it to blank.
Now click finish and try to log in on your windows xp using your username and blank password.
After your log in windows, you can set a password which you can remember
Was this helpful?
Yes
No
Solution #4
posted on Jul 18, 2008
Not Rated)
mdferozali
Rank: Guru
Rating: 88%, 51 votes
Dear Tured:
If you set the password for windows please try the steps below if it is bios password you need to contact your computer manufacturer
  1. Reboot your machine.
  2. Press F8 before the Windows boot screen appears.
  3. You will be be prompted with a boot options menu.
  4. Select the Start Windows in Safe Mode option.
  5. Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
  6. Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
  7. Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
    • The Safe Mode Welcome screen might display some of the other users on your system.
  8. Login as the admin.
  9. Press Yes at the prompt asking if you would like to continue using Safe Mode.
  10. Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
  11. Reboot your computer. As long as you don't press any keys (i.e. F8) during the boot-up the computer will startup normally.
  12. Login as the user for which you set the password.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Windows XP
Questions and Unsolved Problems for Microsoft Windows XP
Do you recommend Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC?
Answer
Answer
I purchased New HCLComputer in middle of 2007 thereafter it has been formated privately with... (More)
Answer
where can I download kstvtune.ax for xp sp3 ? my cam won't work without it
Answer
...Exception EOleEXception in module DLL_NETCARD_R.DLL at 0005E682 did not work... smartbro prepaid... (More)
Answer
microsoft windows xp integrated with service pack 2 key- vddf2-jjwm3-x7p27-frhrt-8bvht
Answer
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: Unknown... (More)
Describe your Operating Systems problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating System Experts
Top Computer & Laptop Repairmen
in Las Vegas, NV
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
