2002 Kia Sportage Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where are the spark plugs located? Also where is the loation of the fuel filter/
Colin Stickland
Level 3:
  • Kia Master 22,516 Answers
  • Posted on Jan 27, 2011
Colin Stickland
Kia Master
Level 3:
Answers
22516
Questions
Helped
6999277
Points
66324
If this is a petrol variant then petrol filter should never need changing unless its corroded and an external fitting ,most modern vehicles have a gauze filter inside the tank anyway,Now the spark plugs are under the plastic cover on the top of the engine with a coil pack on each spark plug and the gap should be 25th but some manufacturers specify a wider gap because they use a higher voltage spark than the old classic cars from my day but 25th is not far out for 99% of vehicles
1986 4runner starts good just misses bad and wont accelerate
I would first start with the coil, distributor cap, rotor, spark plugs, and the spark plug wires. If that doesn't fix the problem, I would then change the fuel pump (located in the gas tank) and the fuel pump relay switch (located in the kick panel on the driver's side). If that still does not fix the problem, I would change out the Air Flow Sensor (located on top of the air filter box), and the Fuel Sensor (located where the air filter tube attaches to the intake manifold).
Need gap spacing for spark plugs. Wondering about the location of the fuel filter
Hello: There should be a white placard under the hood giving you the spark plug gap, Its called an ession label for your engine, the gap probably is .060 of an inch. The fuel filter should be behind the fuel tank or to the passenger side under the rear of the car.
Ai have a 88 chevy s-10 blazer it stall when i drive a block like it starts to cut out does it need a fuel filter, if so is it under the truck or does it need spark plugs only or does air filter only...
I suggest a full tune up.
1. Air filter.
2. Fuel filter, carbureted engine filter is located inside the line fitting where it attaches to the carburetor. Fuel injected engine filter is located in-line under the truck near the tank.
3. Oil and filter.
4. Spark plugs and wires.
5. Distributor cap and rotor if applicable.
6. PCV valve.
2helpful
Locate fuel filter Spark plug gap.
plug gap 0.044 inch
The fuel filter on most Mazda cars can be located on a bracket in the left rear of the engine compartment, next to or beneath the brake master cylinder fluid reservoir.
Looks like this:
1helpful
Low power and missfire, have replaced bad distributor and rotor. 2000 Oldsmobile Bravada AWD. Where are the fuel pump and filter located?
I have replaced Distributor cap, rotor, wires, and spark plugs in my 2000 Oldsmobile Bravada AWD smart track. To replace one spark plug I had to collapse the steering column, but everything went O.K. Did you marked the wires?. Did you reconnect them in the firing order?
The fuel pump is located In the fuel tank. Remove the fuel tank and take the fuel pump out from the top. This is part cost $300 and need some skills to be replaced.
The fuel filter it is directly in front of the fuel tank. Another one is incorporated with the fuel pump.
6helpful
2answers
How to replace spark plugs on 2000 jeep cherokee classic 6 cyl.? Also does 2000 cherokee have inline fuel filter?
TO REPLACE SPARK PLUGS YOU REMOVE COIL PACK MOUNTING BOLTS THEN REMOVE THE COIL PACK WITH BOOT OVER THE SPARK PLUG.YOU HAVE 6 INDIVIDUAL COIL PACK TO EACH CYLINDER. YOU NEED A 3/8 RATCHET WRENCH - LONG 3/8 EXTENSION -SPARK PLUG SOCKET - SPARK PLUG GAUGE.AND TORQUE WRENCH.THE 2000 MODEL JEEPS FUEL FILTER INSIDE THE TANK.1993 - 1996 MODEL JEEPS FUEL FILTER LOCATED LEFT SIDE OF THE VECHICLE NEAR THE FUEL TANK.
My 1991 lexus will not start when the ignition is turn with the key. The ingine constantly turns over without starting and preceeds to kill my batterie.
Well if it is cranking you need to see if you are getting spark and fuel.....Try turning the ignition on without cranking the motor....You should hear your fuel pump making a whirring sound for about 3 sec.and then shut off...If no sound from pump (which is located in the fuel tank) check the fuel pump fuse If fuse is good check fuel pump relay...If all checks out ok with fuel pump take into consideration when the fuel filter was changed last....I dont recommend adding fuel injection cleaner to your tank without first changing fuel filter...additive is designed to break up debris thus breaking up all trapped particles in filter sending debris through your injectors.... To check for spark pull the #1 spark plug wire and place it on an angle on tip of plug (allowing you to see if spark is present) have an assistant crank engine while you look for spark..... Do not hold spark plug wire in your hand while engine is cranked.... I hope this has helped you
1helpful
2answers
01 ford ranger 4x4 4.0V6-- rough idle like it wants to cut off. loses power or studders under acceleration. struggles to get up to 55 or 60
I agree. Try replacing the spark plugs, install new spark plug wires, change the air filter, change the fuel filter, and test the battery and alternator. Run a bottle of fuel system cleaner and water remover through it. To replace the spark plugs you'll most likely have to go through the wheel wells cause of their hard accessibility from the top. The fuel filter is located on the inside of the frame on the driver's side. Hope this helps. God bless
1helpful
2answers
Loation of spark plugs on 2006 chrysler sebring
They go into the cylinders through the middle of the valve cover.
2helpful
IAT Sensor Location on a 2005 Nissan Altima
It is small and round (2 wire connector) and located either in the flexiable air intake hose to the engine or in the engine air filter housing.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
