When i move my laptop sideways, i get a lound cracking sound and smoke coming from the air vent. i think the problem is related to the cooling unit. i first heard the crackling while i was on the laptop. it happened once, and ever since then when i tilt it, it happens again.
  • 3,940 Answers
If you are getting a loud crack and smoke, you are having an electrical short inside the system. This could be the battery or some other electrical component.
Regardless, STOP USING THE SYSTEM IMMEDIATELY!
Have the system inspected by a qualified technician and ensure that there is no fire or electrical hazard.
There could be a problem with the battery shorting out, which has resulted in at least 7 system fires during the sony battery recall. There also could be a broken or bad connection in the system that is grounding and arcing, again a fire hazard.
Posted on Jul 18, 2008
Loud thumping sound!
Probably the same issue I am having with the A/C actuator. Move your selector from dash vents to floor vents, then to defrost and see if the sound stops. Mine is stuck on either floor or defrost right now, won't direct air out through the dash vents. The gears in the actuator motors strip and the thumping will get worse until the gear is finally worn down and won't work at all.
Apr 05, 2013 | 2009 Dodge Ram Pickup 1500
Why is there smoke flowing from my ventilation vents? My truck is not over heating and there is no smoke coming from the engine. I have a 97 Ford, Expedition.
You mean from the aircon vent.Your cooling unit need a good chemical wash.Ice is forming in the cooling unit, the air outside is hot thus is the cold air forming smoke from contacting the hot air.
Jun 01, 2012 | 1997 Ford Expedition
My new Coleman Mach 15 seems to be having a hard time cooling when the heat hits. I have a tstat gun to check to temp of the air coming out of the vents. In the morning when it is cooler, it is cooling...
check and see if someone has not installed a filter on the return .. The it sounds as though your in the sun for the heat of the day. I also sounds as though it may be a bit low on gas . Remember that these unit are kinda a one size fits all arrangment. as they are travel trailers. But you should be able to keep it to a 45-55 degree supply air . If you can i would move it to a shady spot for the afternoons if possible.My unit take 2 ac to cool it on hot days and its insulated for cool climates . again 40-45 degree discharge should be what your looking at in the cool of the mornings.. Hope this helps a little.
Aug 07, 2011 | Coleman Mach 15 Air Conditioner
We own a "converted" condo unit in a building that was previously apartments and now each unit is sold as a condominium unit. I have read about others having issues with cigarette smoke coming in through...
Hello,You need makeup "fresh" air intake vent added.You have a attic fan or when a clothes dryer,range hood,bathroom fan runs it pulls the house into a vacuum or negative pressure.It will pull air from anywhere it can to balance the pressure.Try leaving a window open a little bit for a couple of days(if you can do safely)and see if it works.Then you need a outside air vent installed.I assume the AC intake/return are seprate from the neighbors.
Oct 10, 2010 | Honeywell Electronic Programmable...
The airconditioner in my car works its cool through the floor vents and the vents on the dash but no air is coming through the main air vents ? the car is a vs berlina with climate control ?
I would say that the control unit isnt switching properly,from the mode button moving the vents air flow direction,best bet is to try and swap a mates one and see if the mode changes the airflow to the main vents,it may be the unit isnt allowing the switching,i think theyre vacuum controlled
Nov 19, 2009 | 1993 Mitsubishi Diamante
Smoke Rollin out of my vents! HELP!
Hi
I think if it was carbon monoxide, you would have your wings by now ! .....or horns ?
Sounds more like coolant, is your Bronco smelling rather fishy these days ??
If so, it´s definitely your heater matrix leaking !
A Jar of Bars Leaks, in the cooling system might work wonders.
Good Luck !
A FixYa rating would be nice !
John.
Feb 12, 2009 | 1988 Ford Bronco
Puff of smoke from crack between heater vent and dash
antifreeze i think,heater matrix leak ,try putting a rad leak stopper in
Jan 19, 2009 | 1998 Ford Contour
No air flow upstairs
Cold air is denser than hot air, so is harder to move. All vents have some mechanism to regulate flow, so close all of the downstairs vents. Check to see if your furnace fan motor has more than one speed, & set it on maximum. Keeping the fan on all the time will help as well. If all else fails, you may need a more powerful fan motor.
Jun 16, 2007 | Weather King 12AJA4801AH Air Conditioner
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
