I have a simple stereo speaker from Radio Shack. Small metal case with two wire input latches. Each box has two speakers in side. Both speakers boxes went out at the same time. I wasn't there when this happened. I hooked the speakers up to a boom box. No output. Internally everything looks okay. The only electrical component I can see is an electrolytic capacitor. It looks intact. The resistance across the input read infinity. Any hints?
  • 4,234 Answers
You need to measure across the speakers themselves n ot the crossover (cap). If these are 8 ohm speakers, an ohm meter will read about 6 or so. That is because both impedence and resistance use the same measurement. With an ohm meter you are measuring resistance. The speakers are rated using impedence.
If both speakers are open (measure infinity), I would suspect a problem with the stereo that caused them to go open. With the stereo on and playing something (radio,cd , or whatever) use a DC voltmeter to measure between the speaker terminals (Red/Black). You should read essentially 0 no matter what the volume. If you read any DC more than 3/4 V, the problem is with the amp section of the stereo.
Dan
Posted on Jul 18, 2008
Radio wiring identification 98 dodge ram 1500
Car Radio Constant 12v+ Wire: Red Car Radio Switched 12v+ Wire: Red/White Car Radio Ground Wire: Chassis Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: Orange/White Car Stereo Antenna Trigger: Yellow Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: Behind the glove box. Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Dark Blue/Red Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 21, 2016 | Jeep 94-97 98 99 00 01 Dodge Ram 1500...
Tip
How to Build: Antenna Tuners
Get you a metal box about 4 inches X 4 inches. Use 2 female Cb antenna inputs from old Cb radios or Radio Shack. Get a old Am radio tuner out of a AM radio(530-1700 khz.) Buy or scrap up some copper wire; big gauge I used. Wound 8-10 turns about " 1 inch round close tight wound. Solder to AM tuner- C1 it shall say on top of Am tuner. Solder Center of Am tuner to Ground(Metal box). For those who know electronics the Tuner is 0-365pf Am band 530-1700khz types. OK, back to assembly. drill a hole for the Two Female Cb Inputs on both sides of metal box. Attach copper wire inside to center taps of Inputs on both sides. Drill a hole for Am tuner and Screw on its lock nut and place a knob on it. Solder all grounds of Female Antenna inputs and Tuner Ground and all Grounds to metal box. Use a washer and Bolt to lock down Grounds to Box. This is how it operates after you use a Jumper to hook to TX of Cb radio. Antenna to other side. Its just a simple L/C network. The Tx travels through copper wire(coil) inside box and gets shunted to ground by the right level of PF Capacitance. The operator tunes it in to get a close to 1.1 to 1.5 SWR ratio. Its simple, but helps with bad Antennas.
on Apr 01, 2011 | Radio Communications
If you can help me i need to know if it is possible to wire a amp into a 2002 landcrusier stock headunit cheers
yes, there is an amp turn-on wire from the head unit (black with a red stripe). You will need to add a power wire and fuse from the fuse box to run the amp. You can use the speaker outputs as inputs to the amp, depending on what you are trying to do. Please let me know if you need more help, and identify the amp model as well as the speakers you will connect.
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Black/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Black/Red
Car Stereo Amplifier Location: Under the center console.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): Yellow
Aug 27, 2011 | Car Audio & Video
Best Buy installed new stereo in my 1996 Z3 - Now my stereo stops playing when I put the drivers side window down. My car recently started blowing a fuse. Help...it's been almost 4 years since I had the...
:o( you're going to have to pull the radio out to see what they did. They probably added a wire to an inappropriate circuit to power the new radio or amp. I will paste your factory wiring colors below. If you now have an extra wire, that is the likely culprit. Trace it to see where they hooked it in. If it isn't going to the the fuse box and using an extra slot, make it so by connecting it to the cold side of the fuse and put an approprite size fuse in. To determine the fuse size to use, you can compare the wire gage to other cold side wires and use a fuse the same size as you see being used for similar gage wires. Let me know if you have more questions.
1996 BMW Z3 Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Gray/Red
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: White
Car Stereo Amplifier Location: Passenger Kick Panel
Left Front Speaker Positive Wire (+): Yellow/Red
Left Front Speaker Negative Wire (-): Yellow/Brown
Right Front Speaker Positive Wire (+): Brown/Black
Right Front Speaker Negative Wire (-): Blue/Brown
Left Rear Speaker Positive Wire (+): Blue/Black
Left Rear Speaker Negative Wire (-): Yellow/Brown
Right Rear Speaker Positive Wire (+): Blue/Violet
Right Rear Speaker Negative Wire (-): Blue/Brown
Oct 26, 2010 | 1996 BMW Z3 Roadster
Need radio wiring for 92 astro
1992 Chevrolet Astro Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Stereo Dimmer Wire: Brown
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Right Rear Speaker Negative Wire (-): Light Blue
Jul 27, 2009 | 1992 Chevrolet Astro Extended
I need a audio wiring schamatic for a 1997 dodge laramie 1500
1997 Dodge Ram Truck Stereo Radio Wiring Diagram
Apr 28, 2009 | 1997 Dodge Ram
91 Ford Tempo - New stereo won't work ... Please HELP
here is the radio's wire color diagram, u should be able to fix the problem with this info.Fuse box is on drivers side under the dash.
1991 Ford Tempo Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Apr 12, 2009 | 1991 Ford Tempo 4 Door
Adding extra wire to speakers so I can move speakers.
Red and black are high end and blue and grey are sub speakers.
Apr 15, 2017 | Panasonic SC-AK500 CD Shelf System
1986 Toyota pickup stereo wiring COLOR CODES NEEDED
Car Radio Illumination Wire: Green
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Negative Wire (-): Purple
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Right Rear Speaker Negative Wire (-): White
Sep 01, 2008 | 1986 Toyota Pickup 4WD
Low volume from CD and iPod input
in audio system you have three different levels.
1-mic level which is very small output level.
2-line level(like cd player output)which is higher than above.
3-speaker level is highest one which drive speaker and get sound out from it.
if you want to get control for number 1 and 2 you can use very simple sound mixer.(from radio shack-or other electronic store)
connect your sound source(mic-cdplayer)to the mixer and get out from mixer to amplifier.
Jan 23, 2008 | Peavey Escort 2000 Microphone
60 people viewed this question
 Grubhead
Grubhead
