Question about Electro-Harmonix EH-TM Microphone
A buzzing sound
So I've go the electro harmnoix tube mic, it's running in to the new Apogee Duet, phantom power, and I'm running through Garageband's newest version on my Mac G4...
but.. there's a really loud buzzing sound audible whenever the mic is turned on. At first i thought it was my computer's fan, but it's not- moved the mic away. Is it possible that I just need a better XLR cable running from the output of the mic's power source into the Apogee duet?
any thoughts?! I'm learning...this is somewhat new to me- trying to get started recording a home album. Looking forward to suggestions...thanks!
  • 31 Answers
The cables always a usual suspect, but if you are using a tube mic, wich have their own power supply, you don't use phantom power and it can damage the mics power supply, so take phantom power off that mic and if that doesn't cure the buzz then I would change the cable next.
Posted on Aug 06, 2008
I have recently bought an AKG Perception 120 microphone and plan on recording through GarageBand on my Macbook Pro, but no sound is coming through. please help!
You say you have a XLR to USB adapter....so the version of the 120 you have is the regular XLR version, right? Well if it is, it needs what's called "phantom power" to work. It looks like they have a straight USB version of this mic, and that's what you should have gotten if you didn't want to use anything else. If you still want to use this mic as is, I would recommend a Focusrite Scarlett 2i2. I have one and it's great. I do have a pc though and I'm not sure about Mac. But it's a usb powered preamp that gives you two mic pre's along with headphone amp, and a volume control for your speakers and has phantom power built in. Great unit and around $120. NFI.
May 14, 2014 | AKG Perception 120 Microphone
C1 not working
Sounds like your Phantom power supply may be defective. To be safe, 1st try moving AC plug for Phantom supply to another outlet as sometimes "sharing grounds" can be a problem. If this doesn't help, try using another phantom power source ...many PA mixers have built-in phantom power. If the buzz disappears with a new one, it will be a filtering issue (capacitors) with the old phantom supply.
Apr 19, 2014 | Behringer C-1 Microphone
C1000s hum/buzz on phantom power
possibly the microphone needs more power than your sound card can supply although I cannot imagine as the duet is a good piece of equipment.
Is the duet USB bus powered?
Have you tried another cable? Possibly one wire is defective which means that phantom power will superpose the audio signal. In this case you might hear a hum. By the way this results in 6dB of signal loss. This is why XLR plugs have 3 wires. If connected with a 1/4" jack it has to be a stereo plug (tip, ring, sleeve)
Mar 26, 2014 | AKG Audio Players & Recorders
Just got my sE X1 bundle pack, plugged it in, set the proper settings in preferences and no signal to my Garageband?mac
To connect this mic to your iMac, you will require the following:
  • XLR mic cable
  • Recording interface or Mixer with phantom power
Jan 17, 2014 | SE Electronics SE X1 Microphone
I have a AT4073a, when i plug it into my mac mic port it only gives distortion on garageband and imovie. Is there a driver or solution? thanks Ryan
It looks like the mic you mention requires 'phantom power', which is something the Mac audio input doesn't supply. You may need something like an M-Box or other audio interface to get the mic to perform at peak quality.
Mar 30, 2011 | Computers & Internet
How to use a condenser mic on a mac/in garageband?
If you are sure that the microphone and the cable is OK, it could be that you're phantompower is to low.
Normally you need 48 Volt, you can check that with voltage meter between pin1-2 and 1-3 from the XLR.
regards,
Gerard
Jan 22, 2010 | Audio Players & Recorders
Get sound through a Behringer 1204FX mixer & FCA202 interface
Block diagram available here:
http://www.behringerdownload.de/XENYX_GRP2/1204FX_VIEW_Rev_A.pdf
Where are the trim controls set?
Those mics use both phantom and battery power; are the mic switches set to phantom?
Try using the CD/Tape outputs to the FCA202
Nov 20, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
Sound Problem
What are you running this mic into ?, an interface mic pre ?, a soundcard ? A console/ mixer ?
Since this is a tube mic it should have its own power source and I am assuming you plug that in when using it ? Don't use phantom power on this mic, even though it's a condenser mic, since it's a tube mic wich have their own power supply you don't need phantom power on them and in fact it may damage its power supply.
Jul 06, 2008 | AKG SolidTube Professional Microphone
Electro-Harmonix EH-TM Microphone Logo
445 people viewed this question
Top Electro-Harmonix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Electro-Harmonix Audio Player and Recorder Expert? Answer questions, earn points and help others
