New sony lcd 5 days old just turned it on today got sound but no picture. Menu display doesnt even come up .
    Scholar:
  • 70 Answers
This seems to be hardware issue as you said that you dont even see menu display. As it is 5 days old I would suggest you to contact the reseller so that they can repalce it.
You can also contact sony support for warranty replacement.
Regards
Mohammed.
Posted on Jul 18, 2008
  • 129 Answers
Check the brightness settings.It may be turned down to zero. Otherwise check you have the cable in the right connection.
Have a question.. I own a gateway desktop.. and just recently I left over the weekend for a camp trip.. came back to computer death.. When I initially tried turning it on.. it ran for 3 seconds each time I...
It seems like the MOBO or RAM sticks,because if the PSU is bad you cant hear any fans working.If is 5 yrs old and you dont had spare parts to rebuild it the better scenario is to buy a new one.
Jul 15, 2013 | Computers & Internet
Tip
LCD monitor displays background fine for a second then goes black
If your LCD monitor displays your desktop fine as it boots up and then goes blank after a few seconds, but you can still faintly see your desktop then this may seem like a brightness issue but it's not. The picture displays very faintly, this is because the LCD backlighting isn't working properly. Which in turn is either because (most likely in cases like this) the inverter circuit has failed or the cold cathode tube has blown. If you're new to the electronics business and are not sure how to solder and connect circuits then this is the job for a qualified repair technician. So i suggest you head on down to your local PC store and have a technician take a look.
If you want to try it youself go here to order some spares.
If the monitor switches off and you can't see your desktop faintly then this may just be a power saving issue. Yo fix this check out my other tip here.
If your monitor is less than a year old then I suggest you take it back to where you bought it and have them send it in for repairs or swop it out with a new one. LCD monitors usually have at least a 1 year warranty sometimes it can even be up to 3 years if you register yours when you purchase it or if it's a really expensive screen.
If the monitor is a good 4-5 years old then it may not be worth fixing or may be too expensive. I suggest you invest in a newer widescreen option. LCD monitors have drastically come down in price over the years and you can easily get a wopping 23" for as little as $180.
on Nov 14, 2010 | Computers & Internet
Tip
How to save power even you are still using old VGA Monitor
Older monitors(CRT type) are using complex circuit than LCD, It requires more power consumption than LCD, but you can still save power by 30% through this tip.
1.You must position or install your monitor in a dark area or position.
2.Adjust the brightness control to the level of the black part of the picture must be seen black not gray, or became white.
3. Adjust the contrast control at your most comfortable level.
4.Avoid using bright picture screen saver or blank screen saver.
5.Turn off your monitor manually if necessary.
on Jan 19, 2010 | Computers & Internet
HP desktop computer has trouble starting.
Roland how old is the computer ? computers get old fast.HDD has a exspected life of 5 years PSU also.what causing it you ask lots of use.and how it's used
Apr 02, 2013 | HP Pavilion Computers & Internet
Hi there, I have a toshiba satellite M60-BK3 Laptop. Is only four years old and from couple of days my LCD display is going on standby mode very fast. I try pressing and releasing that little switch which...
A couple things to try, 1 is boot the system in the safe mode (F8 menu at boot) and see if the LCD turns off there. You can also attach an external monitor and see if the external looses video too.
If the system looses video in the Safe mode and doesn't loose video with an external monitor, then the LCD backlight is likely failing
LCDs run about $100 to $150 on ebay
Jun 23, 2009 | Computers & Internet
Screen is too bright, and all text and videos are blurred
If this is a conventional tube-type monitor, you need to replace it. Your symptom is one of the ways a picture can fail. With the low prices on LCD monitors today, it's completely uneconomical to repair the old one. It would need a new tube.
Apr 08, 2009 | Computers & Internet
Monitor display is pinched at the corner
Check if the same thing happens under safe mode.
Safe Mode
Continue to press the F8 key when Windows starts to load
Or hold down the CTRL key
From the menu, select Safe Mode
Same thing? Then I have bad news for you. You need a new monitor. Best to verify for sure on another computer though.
Jan 17, 2009 | Dell Dimension 3000 PC Desktop
Profile 5 shuts off on its on
Sound either like a Overheating or a Power Supply Unit issue. You may need to clean the thermal gel off the CPU and heatsink with a small amount of rubbing alcohol and apply new gel. Make sure your fans are working correctly and make sure there isn't any dust under the fan on the heat sink it self, as this will cause overheating issues... Also, if you suspect the PSU you can usually get a nicer one than you have now for $50, so it is better to go ahead and replace it if it is old. The pop sound makes me lean more towards the side of power / PSU but this sound could simply be from the hard drive lossing power suddenly.
Dec 11, 2008 | Gateway Profile 5 PC Desktop
My emachines monitor has no picture, hard drive is functioning properly. Monitor is black
if you do not get a screen with a LCD monitor its likely you have a inverter problem or BACKLIGHT problem. you might need to replace the LCD backlight or replace the monitor on the desktop.
check to see if the laptop can get a picture by plugging in a monitor to it, im sure theres a connection for external monitor.
theres also a FN (function key) command to switch from lcd to external monitor. always test before commiting to replacing a monitor.
The desktop, you might want to test another monitor on the desktop just to be sure the monitor is gone or dead. if you see on the monitor a OSD saying "No power or No Signal" or you can pull up the OSD(on screen display menu). then the monitor is not dead.
might be the computer even though the computer powers up doesnt always mean the computer is working.
i would check the motherboard for blown capacitors or funky smelling(burnt plastic)aroma. Make sure the computer is off before checking.
get back to us!
thanks
Jun 15, 2008 | Computers & Internet
Will Not Turn On
connect external monitor and check if its works or not ,if ok your display will gone,still same problem i think motherboard problem
Mar 27, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
