Shredders
Problem for Shredders
Generic problem for all Shredders
Paper shredder jam
By janc11 on Jul 18, 2008
Some paper pieces are jammed in the shredder. Won't restart. Could it be a burnt fuse? Can you send a copy of the page from the manuel dealing with this problem OR do you have a solution?
Same Problem
Jan 06, 2009
-   PAPER IS JAMMED. MOTOR RUNS BUT CAN NOT PUT ANYTHING IONTO OPENINGS FOR: PAPER, CD OR CREDIT CARD. NEED MANUAL FOR THIS TO RESOLVE. PLEASE HELP...-   crisner195
Sep 04, 2008
-   My shredder jammed and I got it unjammed but now my motor won't run. Is there a reset or fuse that might need set or replaced?-   janeacaz
Aug 09, 2008
-   Paper jammed in the shredder. Will not start at all-   Guest
Jul 19, 2008
-   I have a Fellowes P400C-2 paper shredder and I am having the same problem with paper jam. I can no longer us the shredder. The motor runs good and I don't thing there is no other problems with it. How do I remove the paper stuck in the sharp cutters?-   annette418
Best Solution
posted on Aug 26, 2008
Very Helpful)
rcj1
Rank: Apprentice
Rating: 95%, 4 votes
If you are really stuck Fellowes has new shredders that are really jam proof ... check out this link for more info ... http://www.fellowes.com/jamproof/
I have one and they work!
Was this helpful?
Yes
No
Solution #2
posted on Jul 23, 2008
Helpful)
jusus
Rank: Wiz
Rating: 83%, 48 votes
Shredder will jam for two reasons
1 over load
2 bad cuttint blade
You will have to removed the screws at the bottom of the shredder. You will have to removed the head from the base. open the door and look under where the head is sitting. you will see two screws. one on the right and one on the left. Also look at the back you will see two screws one on left and one on right. After you removed the four screws, the head
can now be lifted from the base,
Removed all the screws that holds the cover. you will see the jam in between the blades. Try to removed the the paper by pulling the paper while turning the motor fan. NOTE! make sure the power is unplug.
Remember this: the machine will not start if you have a jam blocking the sensors.
Good luck
you can email me if you have problem.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Sep 02, 2008
Somewhat Helpful)
tonysmith335
Rank: Apprentice
Rating: 75%, 2 votes
Check out this video below. I think it should solve any further paper shredder jam problems.
Was this helpful?
Yes
No
Popular Solutions for Shredders
Questions and Unsolved Problems for Shredders
Answer
jammed will not start to much paper placed into shreeder
Answer
wiring diagram for 1050 oztec motor
Answer
ativa HD 800 Shredder is showeing a overheating error message, what should I do?
Describe your Shredders problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Shredder Experts
Top Copier & Fax Repairmen
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
