Question about Microsoft Xbox 360 Console
360 help could you please find a link of the cable or input lead that you are talking about. all i have is the factory cable that came with the 360 from factory. ohh and thanks again for your time. If you have the HD AV cable (with the red green and blue leads on it), there's an optical output port on the plug itself. Get an optical lead and run it to your TV, which should have an optical input
  • 22 Answers
This is a picture of the HD AV cable:
http://secure.llamma.com/catalog/images/xbox_360_hd_cable_component.jpg
On the back of the part which connects to the 360, there's an optical output.
If you then get one of these leads:
http://www.thericheygroupllc.com/images/optical%20cable%20toslink.jpg
It should send the 5.1 digital audio from your Xbox to your HD. I'm sure your TV should have an optical input on it somewhere!
Posted on Jul 18, 2008
Why won't my universal mc2 wheel work with my xbox 360, are these not compatible. None of the output leads would fit into the xbox 360, so I actually got an adapter lead that fits into one of the 3...
There should be a USB cable that came with the wheel that connects directly to the Xbox 360. Are referring to the Madcatz MC2? If so then you might be missing the USB cable connector? You can't modify the other inputs to feed into the Xbox 360. You need to use the cable that comes with the wheel.
Also, some games are not compatible with the wheel.
Jul 19, 2011 | Video Game Consoles & Games
Trouble with 360 and hdtv
The cable your refering too are called Component leads.
The red and white are for your audio and the remainder are the video. All you need to do is connect the component leads matching up all the colour in the correct ports then using your av/source button change the tv to component
You will still have to connect the red and white audio cable to the tv as well.
that should sort your xbox out.
cheers
Little Dish Fitter
Sep 18, 2009 | Proscan PS36700 36" TV
Xbox 360 sound but no picture can any one help
If you've just bought your xbox 360, then you probably haven't got a HDMI cable.
Which I think you could need.
Aug 18, 2009 | Microsoft Xbox 360 Console
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
CONNECTING XBOX 360 TO SAMSUNG HOME CINEMA SYSTEM VIA OPTICAL
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
Headset earpeice :)
make sure that voice sound is set to come through ur headset and not ur tv speakers.
Jan 01, 2009 | Microsoft Xbox 360 Console
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
Un recognisable picture
try a different set of av cables and or input on the tv and see what u get
Jun 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 Premium
You should have received the lead to plug into your TV you should also have a lead to plug into your PC monitor plus power lead and brick. The lead for the computer monitor would be the lead you need to play on an HDTV. Please rate if useful, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
