Question about Indesit Washing Machines
We have just bought a new door seal for a indesit washing machine please advise how to fit.
  • 57 Answers
Hi to replace the seal take off the metal ring with a small screwdriver at the spring on the front of the machine than take off the seal then take the top off the machine and locate the screw on the metal ring undo a bit then take off seal replace and put back the new seal in reverse order as I have written
Posted on Jul 18, 2008
2 Suggested Answers
  • 1075 Answers
SOURCE: how to fit new door seal on Indesit W103 washing machine
this is not an easy job,go online and down load a copy of the machines manual even check out indesits web page.adrian
Posted on Feb 27, 2009
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
The rubber seal around the door of the washing machine is black and slimy. It doesn't matter how often I clean it, it comes back black.
The problem has been caused by doing too many low temperature washes, this has allowed the bacteria to build up on the seal.
The only long term solutioin is to fit a new door seal, and do more high temp washes, at least once a month, do a 90 degree wash or hotter with powder in, but no clothes.
This is called a maintenance wash, and helps stop build up of bacteria, and keeps door seal clean.
Please rate my solution.
Thanks
Nov 14, 2009 | Indesit WA 115 Front Load Washer
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
I need to replace a washing machine door seal (indesit wm12x). Do i need to remove the top or can i do it from the front ? Any other tips on the procedure would be great. Thanks
It would be adviseable to rempve the top, and also tilt the washer to the rear, as it makes it easier to change the seal, and gives you more room to get your hands in.
Please rate my comments.
Thanks.
Oct 30, 2009 | Indesit W 123 Front Load Washer
How do I change the door seal on my indesit washing machine?
Take the top off, remove the retaining rings around the existing seal, remove the seal by un-peeling it from the front frame
Make sure that you check to see if the old seal has a shape which must be fitted back in the same way (Is the seal a uniform shape all the way around)
Refit the new one and re-fit the retainers
Used a little washing up liquid to get the gasket into place
Make sure that to tighten up the retainers
Oct 03, 2009 | Indesit WA 125 Front Load Washer
How to fit new door seal on Indesit W103 washing machine
Feb 23, 2009 | Indesit W 123 Front Load Washer
Indesit WD12 washer dryer with a leaking door seal
this is no easy job and you will need a copy of the work-shop manual; sometimes they can be downloaded of the internet. There are no real specialist tools, but im telling you now there will be a lot of very red knuckles .good luck.adrian
Feb 22, 2009 | Indesit W 123 Front Load Washer
Indesit we14
Please can anyone advise how to solve this one? Having the same problem. Thanks
Mar 22, 2008 | Indesit W 123 Front Load Washer
W washer
it maybe door electric lock easy to fit,take door seal at the front ONLY,take off the two screws holding on lock,have new one in hand, lock I mean,copy the way the three wires are on the old one,swop for the new one.bye Ire.
Oct 23, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
221 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
