Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
Video the screen is at the right hight on bothe left and right but it is pull down in the middle and causing a three-D effect. I twas fine 30 min prior and now is acting up?
  • Sony Master
  • 3,459 Answers
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Posted on Jan 27, 2009
  • Edward
    Edward Feb 14, 2009
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Diagnose problems
T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 15, 2014 | Samsung Televison & Video
Screen, Image, Lines,
Check and replace its LVDS cable [the cable that connects its T'Con board to panel]. Re-seat it once and check, before replace it. Any loose contact with either side of this cable; or the cable itself is damaged, can cause this fault.If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Toshiba 46LX177 46 in. LCD HDTV
Hi i bought kx 250 f 2004 model . Can the bike seat hight be adjusted to lower hight to soot my wife length. How do i adjust the hight can you assit please?
Koubalink I am short as well, could ride fine, but as the bike is tough to kickstart, I needed the height to get a full range on the kickstart. Bought a Koubalink, fitted it in about 30 mins and worked out perfectly. Cheers
May 29, 2012 | 2004 kawasaki KX 250 F
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
When we 1st turn on the tv the left half of the screen is black right down the middle of the screen,,,,then 15 mins or so it starts to slowly regain strips of color and finally it has a full picture! Then...
When tv it does have a full picture,the tv it work ok?Yes,tv it is repairable.This tv problems are only have two possible electronic boards causes.1 the tv board that call the T-CON decoders board it is dying,this board sit in the middle of the bottom of the LCD screen panel,it control and decoding all the picture dots pixels before it gose into the LCD screen panel.2 worst cases the main board the tv Tuner signal board is it dying,this board control everythings.Like it take in the outside incomming signals sources,like the tv incomming broadcasting signal cable wire and all the external electronic unit divices plug it into the tv.80-90% this tv problems it is the causes by the tv T-CON decoders board only.Tries websites like Shopjimmy.com,Ebay.com to buy a reburbish T-CON decorders board and the tv main board Tuner signal board for the replacement.
May 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Head Cylinder Bolt Torque Spec and sequence. In lb. With a engine 2004. No turbo.
well according to my alldata book its 30nm then slacken 90? and tighten again 90? ,---Well in all honesty i cannot see this being done on a assembly line at three engines a minute where they are pulled down at once with one big air driven socket machine so here what i would do and its old school in fact it may even be older than me which i doubt ,anyway all jokes aside i would pull down first with a rachet in sequence and this invoilves the first bolt in the middle then the one above it then do one each side alternativly easy so you start in the middle and work your way out left then right left then right and so on ,after pulling them down with a rachet this will apply about 30/35lbs ,then use the breaker bar and pull them down again till i feel it stretch the bolts but as your not me you do as i say not as i do ,so set torque wrench to 55lbs and pull them down in order again ,then coffee break and thats compulsory now up the setting to 65lbs and pull them down again and that should do you ,you should not need to pull them down after so many miles this is not a 1959 morris a series engine but a VW state of the art piece of kit
Feb 17, 2011 | 2006 Mini Cooper
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Can not get video to TV
on main windows screen, right click middle of screen, go to properties,
Drag #2 box to the left side of the #1 box, hit apply, enable both displays, hit ok.
Jul 22, 2009 | GPX PD808B Portable DVD Player with Screen
SOny DA90esg sound distord like it have a cold ? any ideas
Check your wiring. Sounds like your "out of phase" The easiest way to tell if this is the problem is to adjust the balance from left to right. all the way on either side should sound good, then move to the middle and it sounds dead. That's it. Find your speaker wire that has the + and the - reversed and switch. If this is not the fix, post a comment and I can help you dig some more. Hope this helps
Jun 24, 2009 | Sony STR-DA90ESG
RCA P61960 Picture is concaved
this is the conversion chip or sometimes chips that cause these effects the chip or chips are about $30 each but labor is alot more $250 -$300
Oct 18, 2008 | RCA P61960 61" Rear Projection Television
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
