Question about Mitsubishi VS-50705 50" Rear Projection Television
No Power VS-50705
When I switch TV on, light comes on - goes off, then blinks 3 times. When I push the menu and input buttons I get 1 blink then 2.
  • Mitsubishi Master
  • 19,396 Answers
Check this movie
Mitsubishi Error Codes
Posted on Jul 18, 2008
  • Ginko
    Ginko Jul 18, 2008
    To check the error code the following procedure should be performed:
    "3. Error Code Operational Check
    Note: The TV must be in "Shut Down" and not manually switched Off, to perform the Error Code Operational
    Check. When the TV is switched Off, the code automatically resets to "12" No Error.
    Press the front panel "DEVICE" and "MENU" buttons at the same time, and hold for 5 seconds to
    activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
    Note: The front panel buttons must be used, NOT those on the Remote Control.
    • The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
    • The flashing then pauses for approximately 1/2 second.
    • The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
    Example: If the Error Code is "32", the LED will flash three times, pause, and then flash two times.
    • The Error Code is repeated a total of 5 times.
    4. Error codes
    The Error Code designations are listed below:
    Error Code Probable Cause
    12 No error detected
    22 Recovery from momentary Reset
    32 Lamp Cover open
    33 Air Filter Cover open
    34 Lamp abnormality
    35 Chassis Fan failure
    36 Exhaust (Back Cover) or Lamp Ballast Fan failure
    37 Engine (DMD or Lamp) Fan failure
    38 Excess Lamp Temperature
    39 Excess DMD Temperature
    41 Short Detected
    44 DVI Cable (between Chassis and Engine) disc"
  • Ginko
    Ginko Jul 18, 2008
    Hope the procedure above worked, it was from Forum: TV/VCR/Stereo Troubleshooting
How to replace cicuit breaker mitsubishi ws 48511
It does not have a circuit breaker but if green light comes on for a few seconds and goes off:
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 29, 2012 | Mitsubishi VS-45609 TV
Our Mitsubishi projection tv went out one day. When we went to turn it back on all it does is blink the green light for a few seconds and then shuts off. What could it be? Where can we look to see where...
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubisi wt-46809 will not turn on. i plug it in and it blinks 3 times then nothing. no error code when i hold menu and input
keep in mind if you unplug set it clears the error buffer.
Try to turn set on and if power light comes on and goes off then do the self check; menu and input for at least 5 seconds and release both buttons.
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Before you rate this information let me know what you find.
SD TECH
Jul 20, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Older medallion 55" 1080...switched itself
PRESS AND HOLD "input" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
SD TECH
May 14, 2011 | Mitsubishi WS-65413 65" Rear Projection...
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I push power button and my 1080 series 42 in. mitsubishi big screen shuts right back off.
Most of these sets have a self check feature:
PRESS AND HOLD “device”(device sometimes is called input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
Let me know what you find and I will tell you what it means.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi Televison & Video
I have a problem with a proj. TV mitsubishi model WS55809 1080 series. When I push the power bottom the click relay sound but doesn't work (rapidly
try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 11, 2009 | Mitsubishi VS-50605 50" Rear Projection...
My tv won't turn on
OK BUDDY IM NOT A HOE FIRST OF ALL AND SECOND LERN TO SPEEK GOOF
Nov 17, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi WS-55909 dm board repair
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
No Power
Good Day, PCMcGee; To start try these: This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Jun 21, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
