Question about GE A730 Digital Camera
Mode dial turns, but does not change modes.
I have a GE A730 and the mode dial will turn ok, but the camera is stuck in auto mode. It will not change. Additionally, you cannot take a picture. Is there any way to fix this???
  • 153 Answers
The camera is defective. Call 800 730 6597. Btw, if there is a memory card in it, try it without and see if the problem still exists.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Posted on Oct 28, 2008
My polaroid iS2132 won't change settings when I turn the mode dial/Can't set the intelligent scene mode.
When you put the Mode dail to the SCN mode, It will enter the last used Scene mode. THEN press the MENU button to select other scene mode.
Don't turn any dail. Use the navigation controls left and right from the OK button, to move through the section. Press OK button to save and activate the selected scene mode.
Success
Nov 17, 2013 | Polaroid IS2132-BLACK 16MP 21X Zoom...
How do I set my Canon EOS Rebel T3i 18 MP CMOS Digital SLR to auto mode
If you mean the auto exposure mode, turn the mode dial on the top of the camera to the "A+" position, between the "P" and the lightning bolt.
If you mean autofocus, set the switch on the lens to the AF position if the lens has an autofocus switch. On the camera, press the AF button (cursor-right) then turn the command dial to select the desired mode.
If you mean the auto white balance, press the WB button (cursor-up) then turn the command dial to select the desired mode.
In the auto exposure mode the ISO mode is set to auto, and you can't change this.
If you need a manual, you may download a copy here.
Feb 02, 2012 | Canon Cameras
Picture has lines on screen and is too bright
First off, make sure that you're in automatic mode, and not one of the camera's manual modes. If so, a stuck shutter is another common failure for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 04, 2011 | GE A730 Digital Camera
I have an auto flash, but it's not flashing. Do I need to somehow turn this function on? If so, where is it?
Follow below mentioned steps to turn flash on:-
  • Rotate MODE DIAL to any one of them Auto, program, portrait, landscape, sport or night mode.
  • Press POWER button to turn power ON.
  • Press Navigation button (left arrow button), Flash mode change each time button is pressed. you can use UP and Down Arrow button to change settings. Set it to FLASH ON.
  • Press OK to confirm settings.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Feb 13, 2011 | Polaroid i936 Digital Camera
Stuck with GE A730 Digital Camera
U can try macro mode without flash.
Mar 30, 2010 | GE A730 Digital Camera
My GE Digital Camera isn't working correctly
It sounds defective. Call 800 730 6597
Trevor Gordon
Jul 13, 2008 | GE A730 Digital Camera
Camera freezes when changed from Auto > Scene
Nikon Coolpix s3 powers on OK when switch is on auto mode, but when switched to "Scene" mode cannot shoot, switch back to auto mode / movie mode, or turn off. If power is turn on when switch is in "Movie" mode, everything is OK. Help!
dr rajeev jain
drrjain3@rediffmail.com
Apr 15, 2008 | Nikon Coolpix S3 Digital Camera
Cybershot dsc-w70 stuck in video mode
Ok! I've searched and searched, so hopefully this will help you all out.
If the videos are very slow moving, you're in multi burst mode. Simple fix, actually...
Press menu button that's below the dial selector. There should be two small options near the bottom of the screen "mode" and the little suitcase.
Go into mode and make sure that Normal is selected. Multi Burst is actually a 16 frame per second function good for sports. It shows as a slow motion video on the camera and a sort of collage on your computer.
Hope this helps. :)
Nov 30, 2007 | Cameras
Noise during video recording
Turn off Continuous AF (auto focus) to prevent recording camera noise during video capture. When you turn off Continuous AF, you may notice a narrower area of focus or depth of field, especially if you zoomed to a telephoto position before recording. Turn the Mode dial to Video, then press the Menu button. Highlight the Continuous AF menu, then press the OK button. Highlight Off, then press the OK button. (On is the default.) Press the Menu button to turn off the menu screen. This setting remains until you change it, change the Mode dial, or turn off the camera.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
GE A730 Digital Camera Logo
50 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Are you a GE Camera Expert? Answer questions, earn points and help others
