I just bought the Antares Avp-1 Vocal Producer. I can't figure out how to connect it to my PA System. I have the Phonic Powerpod 620 Plus Pa System.
  • 682 Answers
Please connect output from vocal producer -to ch1 to ch6 hi-z input in your phonic.
Posted on Jul 18, 2008
How do I hook up my MP3 player to the Phonic 620 plus PA system
Does the pa have an rca or tape input? If so you will need an 1/8" to rca cord.
Nov 14, 2017 | The Audio Players & Recorders
I have no sound
you should open it and look for burnt components like capacitors. they can usually be replaced.
Jun 23, 2014 | Phonic Powerpod 410/S710 Pa Package
I am needing to replace my piezo drivers for the S715 cabinets and they are 8 ohm 15 watt drivers. Will these cabinets only safely handle 15 watts, or can I replace them with higher wattage drivers? I am...
No worries here, in fact you can attach a non-piezo hf driver, coupled with a 2.2uf/3.3uf MKT filter and that should do the job with ease, even better than with piezoelectric devices, hope this helps...
Sep 14, 2013 | Phonic Powerpod 740 Plus S715 PA System
I need schematics for the Phonic 620 powered mixer
I am repairing the same one. Repaired the power supply full bridge rectifier and 15 volt regulator then tried it and the music starts for 1 second before some relay (protection?) disconnects and the music stops. So decided to get the service manual from here - just checking out now, it is for the fan cooled version which is probably the heatsink version I'm working on.
http://elektrotanya.com/phonic_powerpod-620-plus-v1_sm.pdf/download.html
Jan 28, 2013 | Phonic Power Pack 620 PA Package System
My Phonic 410 Powerpod doesn't even turn on
Contact the manufacture of the device. If you have the receipt they should be able to sort something out for you.
Nov 27, 2017 | Phonic Audio Players & Recorders
I tried hooking up a laptop to powerpod mixer it shows music is playing but nothing comes out of the speakers
Which inputs are you using? If you are using the 2T RTN, you will need to engage the 2T RTN button under CONTROL ROOM SOURCE and engage ASSIGN TO MAIN.
Sep 27, 2011 | Phonic Powerpod 820 / S712 PA Package
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
What is the ideal speaker specification to match the 8 channel Phonic Powerpod 820. is it possible to play live gig using this set up ? what is the maximum possible set-up ?
to get the best from this mixer output wise, you need to use 4ohm speakers rated at 150watts each. The 200 wat rating is at 4ohms. You can use 8 ohm speakers, but they recomend speakers at 70watts.
Gig wise, you could do a small location that will cater for about 40 people, but that would be pushing your system to the max.
Maximum possible set up? well there is a way to work most scenarios you are given, but it is not best practice.
Ideally, you know what instruments and vocals you want to go through the system, a rough idea of the size of venues you wil play and then ask questions on a system to suit.
Jan 12, 2011 | Phonic Powerpod 820 / S712 PA Package
Power amp for pa system stopped working
Sounds like you have a power supply problem in the amp. I am assuming the fuse you are replacing is intergraterd into the AC connection. You need to dig deeper. If you are not an electronics person you will need a tech.
Jul 02, 2010 | Phonic Power Pack 620 PA Package B-Stock...
116 people viewed this question
 Grubhead
Grubhead
