Question about Sharp AR-C160 Color Copier
Error code F2-45
Can anyone tell me what error code f2-45 means?
Thanks for any help.
  • Tim Babcock
    Tim Babcock May 11, 2010
    The highest that I see for an F2 goes up to 37. Can you verify that?
  • 62 Answers
Reseat the toner cartige.
Posted on Aug 14, 2008
  • Kevin Shearer Aug 14, 2008
    Means you have a bad toner cartige.
Ihave Sharp AR-C160. WHAT DOES THIS H4-01 ERRO CODE MEAN? How do I clear it?
Posted on Jul 26, 2008
I have a schumacher xp2260 and am getting an error code of r02 but cannot find any information about it. Please tell me what it means and how to fix it.
I have no information on this fault. I suggest you contact the manufacturer directly with the question, but really doubt it will be something you can fix yourself.
Jan 09, 2017 | Office Equipment & Supplies
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
Toshiba e-Studio 456 Error Codes F901
The challenge is with the speed of LGC is not corresponding to the model of the machine installed now try to check it if theres no harness for connecting to the connectors of LGC Board of CN311 and CN316
Jan 09, 2017 | Toshiba Office Equipment & Supplies
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
My sharp color copier Mx 3100n is indicating F2-73 after using 88-1 how do I restore it
Hello Tijjani,
The error code that you are experiencing is as follows;
F2 73 IMPROPER TONER CARTRIDGE DETECTION (YELLOW)
You need to replace the yellow cartridge with the proper part # Item Number: MX 31NTYA, MX31NTYA.
Good Luck!
Rich Lilja
Jan 08, 2017 | SHARP MX-3100N
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Sharp AR-C160 Color Copier Logo
250 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
