Question about CTX Optoma EzPro 610 Multimedia Projector
Will not turn on
Hi
I have a Optoma EZPro 610 that does not turn on. I know it's getting power because I can see the fan trying to move but it does not spin. I have no lights at all. I just got this from a friend and I don't know if the bulb is good. Is there a way to test the bulb? Any help on this would be much appreciated. Thanks!
Hi I have a Optoma EZPro 610 that does not turn on. I know it's getting power because I can see the fan trying to move but it does not spin. I have no lights at all. I just got this from a friend and I don't know if the bulb is good. Is there a way to test the bulb? Any help on this would be much appreciated. Thanks!
Posted on Dec 28, 2009
I NEED TO FIND A BULB FOR THE ezpro-610
This is it (in the USA) http://www.myprojectorlamps.com/projector/Optoma/EzPro%20610.html
You mention CTX & Optoma. The link above is an Optoma lamp for the EZPro 610....also note there is a 610H
Feb 16, 2011 | CTX Optoma EzPro 610 Multimedia Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
Optoma Projector Only Displays White Screen
did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
May 12, 2009 | CTX Optoma EzPro 610 Multimedia Projector
Optoma 716
on the projector, restart your laptop/computer, this will detect automatically. if not then try display settings to 800x600.
Dec 13, 2008 | Optoma (BL-FU180A) Projector Lamp for...
No power to optoma ezpro 739
check the door(cover) of lamp not closed firmly open it and close it firmly.
Sep 22, 2008 | Optoma EzPro 739 Multimedia Projector
We have an optoma ep739. when you turn the lamp on, a message 'fan failure' comes on. the fan is running at what appears to be a slow speed. the red temp light goes on and then the lamp turn off.
Hi there
Try cleaning out the fan by blowing it out with a compressor. Most of the time this is only caused by dust.
If the problem stil occurs , try spraying it on the inside with a lubricant.
If the problem stil occurs you will have to replace the faulty fan.
Very cheap to have replaced.
Apr 02, 2008 | Optoma EzPro 739 Multimedia Projector
CTX Optoma EzPro 610 Multimedia Projector Logo
210 people viewed this question
Top CTX Office Equipment & Supplies Experts
jasbo
jasbo
chinopuma
Level 1 Expert
Arora Singh
Arora Singh
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
