Need replacement installation disc - Computers & Internet
    Scholar:
  • 70 Answers
Dear Sir:
Do u want operating system disc of drivers disc.
If you want operating system disc.
Please contact the manufacturer of the computer they will be able to send you the disc you need.
if you want drivers disc you can download the drivers for the support site of the computer manufacturer.
Regards
Mohammed.
Regards.
Mohammed.
Posted on Jul 18, 2008
Took acer 6733Z-4633 to tech. it wouldn't boot up. he said hard drive bad. he was able to save pictures and some files to USB. now I need to replace hard drive. sent for Acer recovery discs. if I cant...
when your laptop starts if it has F12 option push that and install your first disc and choose boot from cd player then follow instructions
if you dont have the F12 option when you puch the power button toggle the F2 key and go to boot menu and choose the cd player as first boot option and then hit F10 and save install boot disc and follow instructions
Aug 18, 2013 | Acer Computers & Internet
DOWN-LOADING DISC- COMPUTER, BERNINA ARTISTA 730 MODEL SEWING MACHINE
first make sure if you have installed the whole program.
else remove the program from the add/remove pro0grams and then install it freshly.
this will remove any kind of errors
Oct 23, 2008 | Computers & Internet
Tip
How to repair disc-type faucets
DISC-TYPE FAUCETS
  • Disc faucets may have one or two handles. The water is controlled by openings in the two discs. When the discs are rotated to align, the water flows; when the discs are misaligned, the water shuts off. If the discs wear, the worn discs cause the faucet to leak. Simply turning the handles harder will not stop the leak.
  • To repair a leak in a two-handle disc faucet, turn off the water and remove the handle on the side that's leaking.
  • Use pliers to pull the disc assembly out of the faucet.
  • Beneath the disc unit is the seat assembly, or seal. Replacing this special O-ring may stop the leak.
  • You may need to install a whole new disc assembly for faucets that have been used over a long period of time. In this case, all moving parts of the faucet will have been replaced and should last as long as the original discs did. The parts of some disc units snap apart into a separate bonnet assembly and bottom cap.
  • To repair a leaking single-handle disc, turn off both the hot and cold water and remove the handle to expose the disc assembly. Take out the screws to lift the assembly out of the faucet.
  • You'll notice that beneath the disc unit are three O-ring seals. Though unlikely, water could be leaking between the unit and one of these seals. In this case, you may be able to stop the leak by cleaning the disc assembly and faucet body and installing a new set of seals. If that doesn't work, the entire disc unit must be replaced. This will renew all moving parts.
  • Replacing the unit is fairly simple. Place the three O-rings into their recesses in the bottom of the disc unit. Then install the unit and tighten the screws. Finally, replace the handle–and you're done!
on Jan 16, 2010 | Plumbing
Acer 7530 installation disc
if u bought it new and within two years, you should have a backup disc from your initial setup. if it is an older model u can find it on internet. most times for free.
Jul 03, 2012 | Acer Aspire 7530G Series Laptop...
Replaced hard drive acer media recovery disc has 1 of 1 then 1 of 6 have all disc . Have a usb cd rom but it wont install recovery software except 1 of 1 what next
If you never tested the recovery discs, they may be damaged.
You will need afresh install from a windows disc if thats the case
Jun 24, 2010 | Acer Aspire 3690-2196 Notebook
DVD DOES NOT PLAY, BRAND NEW FROM BEST BUY ACER EXTENSA LAPTOP EX5230E-2177 WILL NOT BURN A DVD OR PLAY A MOVIE
first make sure that the drive is installed properly. I would advise you to install it from the manufacturer's site. Let me know if you need the installation files.
Also, it can help if you can let me know if it reads any other discs- like regular discs. Try several different types- burned cd and dvd discs, brand new discs, original discs etc.
If installing it doesn't help and the drive will not read any kinds of discs, you will have to return the laptop to the store where you bought it, or try to return it to the manufacturer, maybe they can replace the drive.
Nov 12, 2009 | Computers & Internet
2001 brake pad replacement 2001 nissan quest
The hard part is pressing the caliper piston abck into the caliper so you can get the new, thicker pads over the rotor. A large C Clamp works best.
SECTION 206-03: Front Disc Brake 2001 Villager Workshop Manual
REMOVAL AND INSTALLATION Pads —Front Disc Brake Removal
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the front disc brake caliper bolts. torx bit. T20?
  1. Support the front disc brake caliper from the front strut and spring assembly using mechanics wire.
  1. Remove the front disc brake pads.
    1. Remove the outboard front disc brake pad.
    1. Remove the inboard front disc brake pad.
Installation
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure the master cylinder reservoir does not overfill and spill brake fluid while retracting the front disc brake caliper piston.
    NOTE: It is necessary to fully retract the front disc brake caliper piston in the bore before installing the front disc brake pads.
    Install the front disc brake pads.
    1. Install the inboard front disc brake pad.
    1. Install the outboard front disc brake pad.
Caution. The outer pads are left and right. put left on driver side.
  1. Position the front disc brake caliper on the front-wheel knuckle and install the brake caliper pin bolts.
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif WARNING: It is necessary to depress the brake pedal several times to position the front disc brake caliper piston before driving the vehicle.
Apr 23, 2009 | 2001 Nissan Quest
How to download unreadable disc for lexmark printer
The printer install disc may be faulty or your disc drive is faulty.
Insert the disc into a different computer, if it can be read then the problem is your disc drive.
If it is your disc drive, turn off your computer, open your computer and remove and reconnect the power and data cables on the "faulty" drive, switch on your computer, let it boot up and install the printer disc.
If it still cannot read the disc then you need to replace the faulty disc drive with a new one.
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Need software install disc
you can get a disk, from the support section. Just look for a link to get a replacement cd.
Jun 24, 2008 | Office Equipment & Supplies
Iriver T30MX Installation disc
I need the drivers for iriver T30MX or the installation disc.
firendly heriberto
Dec 23, 2007 | iRiver T30 MP3 Player
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
