Question about Micrografx Designer 9 Full Version for PC
I am getting an error stating "Designer has encountered a disk I/O error trying to access the file", while trying to open a dsf file. I am using micrografx for more than 2 years now and lately i am getting this problem that to when i remotley connect my office pc and work from their. Any assitance is greatly appreciated.
    Habit-Forming:
    New Friend:
  • 24 Answers
Open the organizer containing the 'DSF' document.
Attempt to duplicate the document into an alternate envelope, or onto a USB memory-stick.
Do despite everything you get a similar blunder message?
Assuming this is the case, at that point, the issue is that your plate drive has an issue;
your concern is _not_ an issue with the Designer 9 programming.
Your circle drive could be "passing on". Reinforcement all your imperative records.
Consider supplanting the circle drive, before it COMPLETELY falls flat.
Posted on Oct 25, 2017
    Brigadier General:
  • 10,406 Answers
Close Designer 9.
Open the folder containing the 'DSF' file.
Try to copy the file into a different folder, or onto a USB memory-stick.
Do you still get the same error-message?
If so, then the problem is that your disk-drive has a problem;
your problem is _not_ a problem with the Designer 9 software.
Your disk-drive could be "dying". Backup all your important files.
Consider replacing the disk-drive, before it COMPLETELY fails.
Posted on Jan 27, 2011
Windows 7 PC, can't save my CK pages in .pdf
Reinstall Creating Keepsakes as an Administrator, as it reinstalls it will process your registry changes and should operate correctly
Sep 02, 2012 | Broderbund Creating Keepsakes Scrapbook...
Can't open Excel files after installing OS X 10.8 Mountain Lion on my Mac. HELP PLEASE!
Try repairing disk permissions by running the Disk Utility application until you get no errors (then restarting).
Hope by doing that you get the solution.
Aug 09, 2012 | Apple OS X 10.8 Mountain Lion
Label created with Zebra Bar One V5 read in Zebra Designer
Hi Jonathan. Did you ever reach a solution? We are in same baot with over 60 Barone v5 formats to convert to SAP. Thanks in advance. Mike
Jul 04, 2012 | Zebra DESIGNER FOR MySAP BUSINESS SUITE V2
Trying to reload Windows OS. Run into
From another computer build a msdos floppy disc, yes floppy disc.
I believe you computer accepts floppys does it not? and i also asume you are running xp, you can try running the startup disc and trying to check disc, but if you cannont procede, i would opt into downloading another copy of the windows and try installing through that method. If the disc dosent load, and you get that error message of the bat, another step will be waiting for you.
May 26, 2012 | Dell Dimension 8400 PC Desktop
I just setup my Asus CM6850 desktop computer and when windows gets ready to setup, I get the error "The computer restarted unexpectedly or encountered an error." When you restart it it goes...
Run System File Checker. From a DOS/Command window type: sfc /scannow
To open a DOS window, boot in safe-mode by pressing F8 repeatedly during the boot process (prior to seeing the Windows splash screen), then once in Windows go to Start > All Programs > Accessories > Command Prompt.
Jul 12, 2011 | Computers & Internet
I have TurboCAD Designer 2D for Mac V.5 December. Last night I opened my old project, made some changes and saved it. Now when I try to open that revised file I saved last night, I get error message:...
Hello!
If autosaved is enabled in your CAD, then most likely you can recover a n sv$ file of it saved in a temp folders. You can rename this file and change the extension from .sv$ to .dwg.
This link may help you find the folder where autosaved CAD file is stored
This link might help you also.
Good Luck!
May 03, 2011 | IMSI TurboCAD Mac Designer 2D 5
Custom home program has encountered problem and needs to close
HI ^^
is this software compatible with your operating system ???
Jun 28, 2009 | Sierra Custom Home 3D (63002)
Husqvarna Designer will not read files
Use 3D Disk Manager to write to the floppy disk that goes into your Designer 1. It will automatically convert the files to .shv for you. Disk Manager is part of the Accessories menu (top right-hand of your menu bar when you have program open). Firstly, read the disk (downwards pointing blue arrow on menu bar), then use either the file icon or the camera icon to put the designs you want on the Disk Manager screen. Then use the Write Disk icon (upwards pointing blue arrow on the menu bar). Write back if you need more information - this can get quite long-winded!
May 04, 2009 | Husqvarna Designer I
Error was encountered while attempting to store the undo state.
Make sure users other than administrators have write access to the Punch folder...
Mar 18, 2009 | Punch Professional Home Design Platinum...
Micrografx Designer 9 Full Version for PC Logo
217 people viewed this question
Top Micrografx Computers & Internet Experts
Tom Chichester
Free Robux
Free Robux
Are you a Micrografx Computer and Internet Expert? Answer questions, earn points and help others
