Question about Samsung Washing Machines
Samsung p1253 hole in outter drum,what is it made of and is this a common fault?
  • 57 Answers
Hi I take it that the outer drum is made from plastic the only thing that would cause this problem is a large coin got into the drum and as the machine was spining the force made it hit the outer drum and chip it making a hole
Posted on Jul 18, 2008
Model wf361. What is causing e3 error?
e3. Drive motor tach fault. This means that the tachometer is not regitering any motor movement when it should. Main reasons for samsung: motor control board fault. Tachometer fault. Motor fault. Also check wireing from motor control board to motor. But this issue is not common at all with samsung.
Feb 15, 2016 | Samsung Washing Machines
Have a 1997 honda accord ex with a trouble code P1253, any ideas what that could mean?
hello ragdollsophi,
I am assuming you have a 4 cylinder engine. P1253 usually indicates a problem with the VTEC solenoid, connector, or wiring. I would recommend clearing the fault. After getting the fault cleared, in a safe area, accelerate the car in low gear to at least 4000rpm for 2-3 seconds. If the fault does not come back, then repeat the drive test a few more times. Assuming the fault does not return, the problem is intermittent.
Jun 25, 2011 | Honda Accord Cars & Trucks
How do you get the rear brake drum off a 2000 dodge grand caravan
there should be an inspection hole on the back side, try reaching inside with a screw driver to back the linings off it will turn hard put thats the way you want to turn, if it turns easy you will tighten the linings to the drum, then simply TAP on the outter edges of the drum will spinning it. lil lube will help.
Apr 22, 2010 | 2000 Dodge Caravan
My zanussi washing m/c is leaking from the front of the drum
Could be door boot seal or indeed the drum having a hole in it, the seal is simple to do drum is not worth while.....Although a good grade Silicone would seal it...
Jan 08, 2018 | Zanussi FLA1101W Front Load Washer
samsung machines have a common fault i have a j1253 and this problem has come up also another problem is that the drum over fills with water this fault is caused by a vacumn pipe which has either a blockage for less water or a hole in it when the drum overfills this vacum pipe is located in my washing machine at the front under the top itis a small pipe which is whitish in colour running from the back of the machine at the bottom along the right side of the machine and travel upwards to a round vacum valve this pipe either gets squashed by the movement of the drum and the concrete balance or in the case of over filling rubs and creates a whole check this pipe as this is usually the cause
Jul 31, 2008 | Samsung WF337AA Front Load Washer
Washer error code
try a hard reset *2767*3855#
Jun 15, 2008 | Samsung SGH-E900 Cellular Phone
Washer leaking
hi tyree. you were on line to me but disappeared. did you get what i sent on what prob may be?
Apr 18, 2007 | Frigidaire GLWS1349A Top Load Washer
Washing Machines Logo
166 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
