Question about Kodak EASYSHARE 300 Photo Printer
The light comes on for being out of ink/toner but I just refilled it?
I put in a brand new cartridge but it keeps blinking the light
  • 149 Answers
Make sure you took the protective label that comes on new inks.
Posted on Jul 18, 2008
The toner light on my printer keeps blinking even with a brand new cartridge in it?
its the toner light or photocondutor light?
Open door and push stop for 15/30 sec.
Apr 08, 2015 | Lexmark E260dn Laser Printer
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
I had cartridges refilled and replaced in my 7150. The cartridge light is blinking as if there are no cartridges there or no ink exists. will not print jeff.price@cox.net
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner?
If you are using a refilled (worst possible choice) cartridge, toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | HP PhotoSmart 7150 InkJet Printer
The yellow spot is blinking and the black dot is
the solid light means toner is low. Blinking usually means either the cartridge is out of toner or the cartridge is having a technical problem. If you pull the yellow toner cartridge and put it back in with no change in result, you will need to replace the yellow toner cartidge
Nov 19, 2009 | HP LaserJet 1500L Printer
The toner light is blinking instead of being on steady
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges.
Also, please follow the appended link to Lexmark's support web site.
Don
http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&productCode=LEXMARK_E120&segment=SUPPORT&question=Toner+Light+keeps+blinking#1
Nov 19, 2009 | Lexmark E120 Laser Printer
ML-2510 Laser Printer : persistent blinking red light
Dear
This problem you will be noticed when toner is 90% empty.
Does the printer is functioning or No. If yes the problem is 90% toner is finished.[10% toner remaining alert]
If printer is not functioning Please change the toner from Genuine dealer. Else your printer fails due to non genuine and refilled toner.
Nov 11, 2009 | Office Equipment & Supplies
Toner light is on and I have a new cartridge in it
The toner sensor where the cartridge is loaded is fouled or you refilled this cartridge and the printer does not reconise the toner inside and thinks its empty ether or sensor or refilled cartridge the printer thiks there is no toner.
1. Did you refill the toner?
2. Brand new cartridge > take it back to the retailer if that does not work the printer will need repair.
Please do leave positive feedback and ratings for your free answer today!!
Oct 20, 2009 | Brother HL-2040 Laser Printer
Blinking ink refill light
Hi, Please follow the steps given in the below document to clean the ink cartridges
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00058182
Also try replacing the refilled ink cartridges with genuine ink cartridges as it might be an issue with the refilled ink cartridges.
Wish
Aug 01, 2009 | HP DeskJet 882c InkJet Printer
Problem with ink coming out on paper
Replace the toner cartridge with a brand new one. There's no such thing as refilling toner cartridges. When it's empty, the drum unit is finished and it should be replaced, not refilled. Remember that the drum unit is sensitive to light, and will also be damaged if exposed to a great amount of light over a perid.
If a new cartridge does not solve your problem, remove the cartridge and check out the charge roller. It's located in the upper part of the "cartridge-room". It's a grey roller. lower the front cover the get easy access to it.
If it looks nice and clean, just leave it. If it is dirty and smutsy, you should remove it and try to clean it with hot water. If it is damaged in any way, it should be replaced.
Still problems ?
Check out the fixing unit. Remove the fixing unit and look at the the big rollers that put out the paper. If they look nice, put the fixing unit back in. If they are burned and dirty, replace the fixing unit.
Good Luck.
Jul 29, 2009 | Lexmark T632 Laser Printer
HP Deskjet 1220C cartridge recognition problem
This happens when the connections on the cartridge get old. Especially when you refill or buy non HP Cartridges, try buying brand new hp cartridges and you might be able to get a couple refill out of them before this happens again.
Feb 09, 2007 | HP DeskJet 1220c InkJet Printer
Kodak EASYSHARE 300 Photo Printer Logo
71 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
