My washer smells - Washing Machines
  • Anonymous May 19, 2009
    my kenmore washer smells
There is a filter in the water pump that can get slimy and needs to be cleaned with bleach. You take off the front lower panel that is attached by torx screws. One on each end and one in the middle. Then the cover will come off. The pump is right in front of you and the filter faces you and can be opened by hand turning the cap. You can wash the filter by placing it in dilueted bleach and check to see if there is anything else in the filter.
David
Posted on Jul 29, 2008
  • 57 Answers
Hi amy the first I would check is the smell coming from the door seal if so just replace it if not check to see if there is something on the heater that could be burning
Posted on Jul 18, 2008
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
After completing a load of clothing, the laundry sometimes has a moldy smell. If it doesn't smell right away, it smells after wearing the clothing and sweat a bit. This is not a body smell - this is a...
It sounds like your leaving the clothes in the washer long after the cycle is finished. Once your clothes smell from the washer they will smell moldy dry.
Aug 19, 2010 | Dryers
Inside of washer smells bad!!
Your smell is inside the washer under the cabinet. You must take the cabinet apart and thoroughly clean it. You must have a small leak that has been going on for sometime now for the moister has mildewed. Lysol will kill the smell on this although it must be cleaned first of all
Apr 28, 2010 | Amana NTW4500V Washer
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My maytag neptune washer smells musty. what is
I owned a maytag neptune washer and had to run dishwashing liquid thru it occasionally to get the smell to go away. Finally we learned about a new gasket retrofit that they were doing which was covered by the maytag company we called and they installed it for free and the smell stopped. I had that washer for about 10 years and probably spent as much fixing it over the years as it cost. I now have a whirlpool duet front loader and love it. no smell and not problems. Try the electric dish washer soap.
Aug 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
May 28, 2009 | Maytag Neptune Washer
Washer empties and strong putrid/ammonia like smell
most likely you do have drainage problems where it is backing up
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Aug 07, 2008 | LG Washing Machines
Bad smell inside my washer
Washer Magic Its a special cleaner they sell at most appliance retail stores (probably not walmart or lowes) please rate my advice>>>
Oct 02, 2007 | Kenmore 23822 Top Load Washer
Washing Machines Logo
945 people viewed this question
Top Washing Machines Experts
