Hi, if you would like to print all what apears on your screen at a given moment you can use the print screen function, you will need to hold the F or Fn key while you click on the print screen key, once you done that, all the information on your screen is copied into the clip board and you will need to paste it into an image, use paints or any other graphic software and start new image then paste into it... the new image will be set exactly to your screen resolution and you can adjust to what you like... you can now print from within the graphic program by going into the menu and selecting to print.... This treck is good only if you want to print ALL what is on the screen including your program borders and you task bar, etc... best of luck
