Question about Kenmore 62722 Electric Dryer
Stuck clothes Let me preface this by saying that the picture was close with this model number but I actually have 417-81142000 as the model number on my dryer. It's roughly 5 years old and it's ruining my clothes. They get stuck as the drum rotates and the heat burns them. Collars, the end of rags,socks....it's not picky. The drum seems to be loose. It "leans" forward onto the front of the dryer causing a gap to form at the bottom of the drum that closes up as it leans into the top. The clothes get stuck as the gap closes and BAM burned and nasty. I'm sure there is something that holds the drum in place but simply removing the top did not reveal it to me.
  • kybo Jan 11, 2009
    Clothes get stuck in the front between the drum and the dryer....burns them up.......it will grab onto any piece of clothing and continue drying but hang onto the item it caugh
  • tenvolt May 11, 2010
    Did this help? I have the same problem with a stacked front-loading dryer.
  • 770 Answers
There are durm glides that support the front part # 5303937139
you can look up and order at www.apdepot.com
Hope this helps
Posted on Jul 18, 2008
Sears washer dryer commbo model 417.94712400 didn't stop filling with water and water went everywhere
Generally you could have two problems. Number one may be a sticking water solonoid that doesn't want to close after the fill cycle has stopped. Number two, if the machine has not started to agitate the clothes that means the timer has not reached that part of the cycle and is stuck in the fill mode. My guess is number two would be more likley, the timers **** out nowand then. Hope that helps
Sep 06, 2012 | Washing Machines
My Kodak EasyShare C713 suddenly takes only black pictures and shows only a black image on the LCD in live display. Playback is fine for old pictures and movies. Can I replace the picture senor element-...
It actually might just be a stuck shutter. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 19, 2010 | Kodak EasyShare C713 Digital Camera
The camera takes pictures with flash, but then as you hit display the screen stays black and the picture was never taken. How can this get fixed?
Do you mean that no picture file was actually recorded, or do you really mean that the resulting picture file recorded a black picture?
If you mean that you're camera is taking black pictures, this sounds like a stuck shutter. A stuck shutter is a common failure mode for digital cameras, and it seems to be especially so for any of the Canon A6XX series (although these cameras are awesome otherwise). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 28, 2010 | Canon PowerShot A620 Digital Camera
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
Last week I was taking pictures outdoors, later on that day my screen went totally black, the green light comes on but the screen continues to stay black, I have changed the batteries
One of three possible problems. First check that you didn't accidentally press the DISP or DISPLAY button. If that's not the problem...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Finally, it could be a loose or poor connection of the screen's flex cables, a very common problem for your model camera. The A620's vari-angle screen is a great option for a camera, but with this moveable screen, the screens data and power cables can and do wiggle loose. It is actually relatively easy to fix by just reseating these cables, but will require opening the back face of the screen of your camera.Please see this other person who had a similar problem with an A630.
May 05, 2010 | Canon PowerShot A620 Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
When I turn on my Canon PowerShot S2 IS camera and set it to shoot mode, the screen is black. A while back, I was able to get the screen to show by toggling with the camera and constantly turning it on and...
For your model camera, pay close attention to the "UPDATE" at the beginning of the above linked article. Who knows, maybe Canon is actually fixing this problem?
Oct 15, 2009 | Canon PowerShot S2 IS Digital Camera
Close Caption problem on Sylvania 6419tc
You are in PIP Picture in picture mode. Turn the PIP option off.
Feb 14, 2009 | Sylvania 6427TE 27" TV
35mm Minolta camera has shudder issues
Depending on what model Minolta this is. Goggle camera repairing and see whats out there for your model camera. Some have a focal plane shutter which is worth repairing. The rest are not worth it. Focal plane shutters are made of rubberized cloth
Dec 14, 2008 | Photography
Won't take a picture
If you research this camera online, you will find this is a very common problem with this model. My research says it is due to the internal shutter becoming stuck in the closed position. Some people have reported success by smacking the camera against the palm of their hand as they turned the camera on - this didn't work for me. I read of at least one individual who was able to open up the camera (camera was out of warranty, and was about to be a total loss anyway)and physically unstick the shutter. I have opened up mine as far as I can find way to get into it and still can't get to the actual shutter - hope you have better luck. I ended up going with a new camera at a more disposable price.
May 06, 2007 | Kodak EasyShare LS443 Digital Camera
Kenmore 62722 Electric Dryer Logo
227 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
