Question about Motorola Mobility RAZR V3
Phone problems whenever i try to send something through bluetooth it says blue tooth link is busy what is the prblem
    Problem Solver:
  • 13 Answers
If you have a bluetooth headset, make sure you switch your headset of completely as it occupies your bluetooth link even if your not currently engaged in a call, then if that doesnt work turn your phone off and on and that should do the trick
Posted on Jul 18, 2008
I need to connect a bluetooth to my razr
Do you need to connect a bluetooth headset , or do you need to start bluetooth file transfers?
In either case, to activate blue tooth on the RAZR V3i go to settings>connections>bluetooth (May appear as "bluetooth link") > hands free> look for device. The Razr will scan for other bluetooth devices. If you need to send files over bluetooth, turn on the blue tooth antenna, and navigate to the files you wish to send. Press the menu button, and press "copy" and select the device you wish to send it to in the devices list. If there is no device, or the device you with to send it to is not in the list, press "look for devices".
Mar 28, 2011 | Motorola Mobility RAZR V3i Cellular Phone
My blue tooth not working of nokia 3110c when i send message to any phone via blue tooth it said failed sending
Thanks for posting your problem on fixya.
I assume that you know the steps to send a sms through bluetooth from your question. So I would suggest you to ensure the following
Both the devices should be within 10m range. Bluetooth should be turned ON on both the devices. Make sure you connected to the destination device through bluetooth by selecting and connecting to the device from the search devices result while trying to send. Try sending them from one phone to the other and back again to see which phone has the wrong settings.
Hope the issue resolves soon and great time. I welcome your feedback for correcting myself if needed.
Oct 12, 2010 | Nokia 3110 Cellular Phone
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
Hi everyone. i just bought samsung link cell but i dunno how to use the bluetooth here. can you help me with this? actually, i tried to but the only command here is copy/move but it only copied/moved to...
before purchasing the phone did you ask if the phone has a blue tooth?.Because from the description you said your phone only send via multimedia message or text.
For a phone to have a blue tooth, in the send options blue tooth phone has three option which are multimedia message, text and blue tooth.
This is just an advice, if from where you bought the phone from they told you it was a blue tooth phone, you can still go back and make complains of the phone and tell them it is not a blue tooth enabled phone.
Have a nice day.
Mar 15, 2010 | Cell Phones
Bluetooth for sciphone
Turn off bluetooth, remove the phone or the other device that is sending, if paired. Turn on bluetooth and its visibility. Try receiving again. Also check with other devices/mobiles
Jul 24, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Problem
reformat your phone.
May 15, 2009 | Nokia 6630 Handheld
Camera phone bluetooth
-First you must "enable" your blue-tooth on your handset.
-Secondly you need to make set your blue-tooth feature to "always visible" (this setting is within your blue-tooth application).
-Third, you need to search for all available blue-tooth devices within your range.
If the kiosk shows as an one of the available devices, try to pair with it. (Note: If your blue-tooth feature prompts you for a pass-code, enter 0000.This also applies if the kiosk prompts for a pass-code.)
If you have followed all these guidelines and you are successfully paired with the kiosk, Congrats! At this point, you will need to send the kiosk all your current pics. Your blue-tooth should give you an option to send and what information your a restricted to send.
Hope this can be of any assistance. Thanks!
Mar 19, 2009 | Cell Phones
I have a lg cu 920 how can i blue tooth songs from my phone
you have to be so close to a person to be able to send them something. if you hit search new device under your bluetooth menu it will show the people with their bluetooth on around you.
Jan 31, 2009 | LG Vu CU920 Cellular Phone
HELP PLZ
have you tried turning blue tooth off then back on a again
Sep 03, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola v3 razor bluetooth
Ok so your phone detects other people's phone in a limited range of area around you through your bluetooth, although your range doesn't really matter. So when you send your freind something through bluetooth does your light in the corner light up?, is your friends phone detectting your phone so it will reciecve what your sending through blue tooth, otherwise I'm not sure.
Feb 12, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
70 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
