Question about Tascam Audio Players & Recorders
I HAVE A TASCAM DIGITAL MIXER TYPE DM-4800. I NEED IT TO CONTROL MY TASCAM HARD DISC RECORDER TYPE X-48. I NEED CABLE CONNECTION AND SETUP INFORMATION
  • 682 Answers
Http://www.manualnguide.com/download/manual-guide/tascam-dm-24-digital-mixer-automation-manual.html
setup information in manual above-i think cable will be found in a music equipment store near you.
Posted on Jul 18, 2008
I just bought a tascam dm 3200 i plug my mic in xlr inputs but cant receive any signal, the manual doesnt tell me how to set up mic for each channel and not sure how to connect to active speakers
This is a very powerful mixer, what do you plan to do with it? Did you receive manual with unit? the manual may take several readings as thus may require steps in a certain order.
XLR is a type of input connector. A microphone is not a microphone. Is your mic a dynamic or condenser mike? The condenser mic requires phantom power is it on? Are you using quality cables or inexpensive cables Does make a difference. The unit has outputs.. Let me know what help you need. Also the best solution would be to call Tascam they will help you.
Mar 24, 2018 | Tascam Audio Players & Recorders
DEAR SIR/MADAM WHEN I TRY TO RECORD MY VOICE VIA MICRO PHONE SINGING WHILE THE CD MUSIC TRACKS ARE PLAYING I COULD NOT RECORD THAT TO THE MINI DISC.PLEASE ADVISE ME HOW COULD I CONNECT IT DIGITALLY
It is much easier to use an analog mixer and microphone thru the mixer. I would plug the microphone into the mike input on the mixer and then the Karaoke machine to stereo LINE inputs on the the Mixer, then Mixer Output or Tape Output on the mixer to analog LINE IN on the MiniDisc recorder.
Let me know if you need more info.
Jan 16, 2016 | Tascam Audio Players & Recorders
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
Tascam md-350 "cannot copy" error
Like all home recorders, yours will not let you digitally record digital originals. The Serial Copy Management System (SCMS) is designed to prevent piracy.
Unfortunately it also means you cannot copy your own digital originals digitally.
Record them via the analog input. It will sound fine.
Nov 06, 2012 | Tascam MD-350 Advanced MiniDisc Recorder
When using the DM-4800 I hear a loud hissing/buzzing/digital sound. I suspect it to be a clocking problem. Everything is functioning normally until i push up any of the faders. when i do this, it results...
Just make sure that your input levels are adequate. Some digital noise will occur if signal levels are so low that they are using only a few bits of the dynamic range of the digital numbers of the unit. The idea is to have the gains balanced througout so that all signals are in the normal operating range. Make sure any UNUSED or undriven channels are MUTED. Open circuit inputs MAY have significant noise... this is a statistical thing that has a minimum level dictated by the laws of physics.
Sep 06, 2011 | Tascam DM-4800 Mixer
I have a Tascam TM-D1000 digital mixer that has a TDIF output and want to connect this to my computer. Do I need a PCI 822 card or is there another option to connect?
I have a TMD1000 connected to my computer via the RCA ( Red & White) outputs on the mixer to an M-Audio 2496 Sound card in the computer.
also via the Digital out on the mixer to Digital in connector on the card.
I then edit recordings on the computer with Cubase pro.
Nov 28, 2010 | Tascam PCI822 Digital Audio DTRS Interface...
How do i transfer from tascam DA-30MK11 to computer
From my personal experience, and assuming that you want to do this purely in digital format in order to preserve quality, you need to connect an RCA cable from the digital (SP/DIF) output of the DAT machine to an SP/DIF input of a sound card installed into your computer. Please note that the sound card on your computer must have digital input capability. Also the Digital input (sometimes labeled ‘CD digital’) must be selected in your software as part of the recording controls. To do this, open Volume Control, click ‘Options’, select ‘Properties’ and then select ‘Recording’ (as ‘Playback’ is usually enabled as default), and select the ‘digital’ input. Then using a reasonably good a sound editor or other recording software, start recording keeping in mind that you should configure the software to accept whatever audio data format is used on the DAT tape (i.e. 16 bits, 44.1KHz, or 48 KHz etc) I’m my case the software usually displays a box with these parameters before starting to record. Hope This helps. Good luck!
Nov 03, 2008 | Tascam DA-30MKII
Tascam DM-24 Digital Mixer Problem
I purchased a used Tascam DM-24 mixer about 2 years ago, and it 's been running great. Just about 2 months, it frequently shut itself off with a message:
" Power Supply voltage (+5V) is too low for stable operation. Please restart DM-24".
Of course, many attempts of restarting the board, but it won't turn back on after several hours later, and only lasts about half a day work only. Very frustrating. Any idea I could get help or fixed? million thanks for suggestions. Brian
Dec 31, 2007 | Tascam Quantegy 120 Minute Digital Audio...
169 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
