Question about Refrigerators
Magic Chef 8 bottle wine cooler model MCWC8DSCT. When turned on light flashes and fan starts to move but doesn't. Sounds like a relay keeps switching off and on. Do you know what the problem is? And which part(s) are needed to fix it? Thank-you, JJ_TORLoozee@hotmail.com
  • 6 more comments
  • gwartneys Jul 27, 2008
    Same problem. Worked fine for two years. Then one day the display panel and inside light started flashing and it stopped working.
  • jlight2304 Nov 29, 2008
    I have the exact same problem......the lights flash, the fan starts to move, and it sounds like a relay is clicking.....but the unit won't refridgerate.
  • bv59 Dec 20, 2008
    Exact same problem. Also worked for almost two years then this.
  • Anonymous Apr 11, 2009
    Exact same issue.
  • barry_morton Apr 15, 2009
    Lights flash, clicking sound, no cooling. Only 6 months old. Can it be fixed?
  • txxg May 02, 2009
    Have the exact same issue. Not sure if it's a power board or fan control board. Clicks and flashes after it was turned off and unplugged to move during kitchen rennovation. Same outlet, same area when completed. Nothing was done to the electrical outlets.
  • bmover Nov 17, 2009
    My cooling fan is just worn out where can I buy one ? Its 3.5inches, 12v dc .19Amps. Other than that the things works. I put a small fan on it and it cooled right down.
  • Jacektur May 11, 2010
    Same issue as all of you .Replaced pcb but still doesn,t work.I'm going to order semicuductor and see what happens.U can get all parts from
    mcappliance.com
  • 59 Answers
I have the same problem as stated with the light flashing and fan tries to rotate. I found by disconnecting the power wires to the cooling unit, the fan rotates. light works and no clicking sound.
I suspect the cooling assembly is defective causing the unit to not work properly.
Does any one have a part number for this part and where I might purchase the cooling unit. RepairClinic.com does not have thhe cooling unit.
Posted on Sep 01, 2009
  • JIm McCrosky Oct 02, 2009
    I have the same unit with the same problem. Here is a good way to troubleshoot the problem.
    First go to any auto parts store, I used O'Riely's, and buy a single element light socket and bulb. I used a Calterm Ford socket assembly #08551 and bulb #1156.
    Next find the 12 volt output wires on the power supply PCB board and hook up your test light. Plug in the wine cooler and see if the bulb burns bright or dim. If the bulb is bright the PCB is OK and your problem is in either the main pcb or the cooling unit itself.
    When I hooked up my test light up to the power pcb the bulb would flicker confirming the pcb was defective.
    Note: You cannot just use a meter to check the voltage because the meter does not simulate a load on the unit.
2 Suggested Answers
t0pc4t
  • 132 Answers
SOURCE: Magic Chef wine cooler clicking
If I was abetting man - I would suspect that the fan is polarised, and has been wired incorrectly..
Check that there is nothing obvious in the way of the fan blades..
Posted on Aug 15, 2008
Majic Chef 8 bottle wine cooler MCWC8DSCT
Can you post any pix? The model number ain't coming up at searpartsdirect.com
Mar 28, 2013 | Magic Chef Refrigerators
Magic chef wine cooler (30 bottles) is not cooling any more
if its clicking every few minutes its the ptc relay.located to the left of the compressor behind shield with 1 screw.go to repairclinic.com...part# 1206838
Jul 21, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
MCWC8DSCT
to the left of compressor behind plastc cover with 1 screw will be the ptc relay on top .its got 1 wire going to it.wiggle it off to the left...go to repairclinic.com ...part# 1206838..
Nov 22, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine refrigerator is not worjung
IN YOUR USER MANUAL THERE WILL BE A TROUBLE SHOOTING SECTION. CHECK IT OUT AND IF POSSIBLE GET A TECHNICIAN.
Sep 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
Mar 31, 2009 | Magic Chef MCWC45A Wine Cooler
Magic Chef MCWC8DSCT Wine Cooler
the magic chef is probably the ptc relay.to the left of compressor is a shield with 1 screw behind it .on top is the relay with 1 wire.wiggle it off .go to repairclinic.com...part#1206838
Nov 07, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
I had the same problem. I fixed the problem by replacing the main cooling fan that is mounted over the electrothermal cooling unit.. Fan can be ordered from RepairClinic.com.
Sep 16, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Aug 15, 2008 | Refrigerators
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Refrigerators Logo
1,102 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
