Great site. I have a Simplicity SPAC 8499-5 Portable Air Conditioner and it was working fine up until yesterday (~2 years old). The unit is running and the fan operational but while the green light for Cool/Dry is illuminated that actually cooling unit for the air conditioner is not kicking in. The system is just blowing air (like in Fan) mode. I have checked the water reservoir and it is empty and placed properly in the unit so the switch is engaged but no AC.
  • 54 Answers
SOURCE: Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Posted on Jul 02, 2009
  • 36 Answers
SOURCE: Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
Posted on May 27, 2010
  • 251 Answers
SOURCE: Haier air conditioner will not kick on to air
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
  • 4736 Answers
SOURCE: My unit is flashing a
You may need to reset the unit, if you did not turn it OFF & unplug it when you drained the tanks
To reset the units electronics, turn the unit OFF and unplug it for 15 minutes. After the time has elapsed, plug the unit in & turn it ON. The electronics should have reset and reverted back to the original factory settings. If so, you can adjust the settings to where you like.
Hope this helped you & thanks for choosing FixYa.
Posted on Sep 09, 2011
TheMobilian
  • 8220 Answers
SOURCE: mitsubishi slit air conditioner model MSZ-GA80VA I turn on and turn off cauting out door unit fuse blown I replaced still The fuse is blow is the out door air con unit Note.unit in door stop not inpos
turn off everything electrical in house and retry with good fuse or breaker if still blows unit needs repair possible shorted capacitor? if it runs it may need to be on its own circuit dedicated to it alone
Posted on Jan 05, 2017
Need to fix leaking on my simplicity portable air conditioner 6077 and how the drain works
If it is water in a thru window installation you will need to tilt the unit up a little so the condensate water drips outside. I hope this helps! Thank you and please leave feedback.
Jul 11, 2016 | Heating & Cooling
My unit is flashing a red light in the water full indicator. Therefor the air conditioner will not function. Both water tanks are completely empty. It is a portable Danby unit. Model SPAC 8499-3. Any...
Sep 09, 2011 | Danby Heating & Cooling
I bought a 7000 BTU Simplicity portable air conditioner as is from Canadian Tire. It's only sold with the system unit. I don't see any hot air hose, but I also don't know where the hose would attach to the...
The hose has an adaptor, which is recantgular in shape, that attaches to the grill in the back, right side facing. If you do not have this adaptor you would have to order it from an appliance repair depoe, as well as the hose. Good luck. Google, simplicity spac7088 owners manual and you will see what i mean. gdm1454@yahoo.ca
Sep 02, 2010 | Danby Portable Air Conditioner
Simplicity AC unit, reservoir by pass
sounds like you possibly attached the tube to the wrong spot. why not run the tube outside, you are risking an overflow that will not shut the unit down
Jan 30, 2018 | Heating & Cooling
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
Searching for manual for my simplicity portable air conditioner
Yes can you please provide the make and model # so We may help more.
Jun 13, 2010 | Heating & Cooling
Unit leaking water,
if your humidity is excessively high unit wont be able to cope,try it again after hi humidity lowers
Jul 27, 2009 | EdgeStar AP450Z Portable Air Conditioner
Danby-Simplicity SPAC 1220081 - manual gives no indication on how to activate the ionizer function, ie: get the light to turn on suggesting its working. Any ideas? kms. Oops - typo in the model # correct...
I talked to the Danby rep and he said you activate it by pressing the 'fan' button on the control panel for 3 seconds until the ionizer indicator light activates/deactivates. I haven't tried it yet (I'm at work) but I'll give it a shot when I go home.
Jun 23, 2009 | Danby Portable Air Conditioner
HBD 160-H Hampton Bay Air Conditioner
The fan alone on an A/C unit draws alot less amps than a fan and compressor. I would guess that your fan and compressor draw around 15 amps when bnoth are on. The unit should be on its own breaker or fuse (whichever you have. As things get old, like fans and compressors, they wear out and will draw more amps.
I see you have 2 choices,:
1) place the A/C on its own circuit with nothing else on it. This may buy you some time until you can replace the unit.
2) Buy a new A/C as the newer units are more energy efficient, and last longer.
Jul 07, 2008 | Hampton Bay HBLG5004 Air Conditioner
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
