Question about GE 25942GE2 Cordless Phone System
CL flashing - setting time and date
How do I set the time and date. I don't understand the instructions for this at all. Should this eliminate the flashing CL
  • 1 more comment
  • vicki_winch1 Aug 12, 2008
    I can't figure out how to set time and date. Please help.
  • Anonymous Nov 28, 2008
    manual for phone25942ge1
  • samzookie Jan 02, 2009
    I have the same problem.... CL flashing on the main base... there aren't any little buttons on the base nor will my call waiting have anything to do with this... HELP!!!
You dont--your phone company does that when the caller id is active
Posted on Aug 05, 2008
The answering machine clock settings are the back of the base. Set the time and day with these and the flashing CL stops.
Posted on Aug 16, 2008
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Flashing cl
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Mar 26, 2009 | GE 25932 Cordless Phone
GE Base 25942 Flashes Cl
You can download the phone manual here:
http://www.home-electronics.net/ge/pc/IB/25942GE2_IB.pdf
It explains the time/date setting (done from the handset).
Jan 04, 2009 | GE 25942GE2 Cordless Phone System
Cl and 0 flashing
Dec 28, 2008 | Uniden Cordless Phone
Answering machine is flashing CL after I lost power
set the CLock by holding down the buttons on the side of the answering machine - top button for day, middle button for hour, bottom button for minute
Sep 25, 2008 | GE 25932 Cordless Phone
CL code
My phone was also flashing CL and the 0, after a power outage. After I set the date and time it was fixed. Press the flash button on the handset and use the caller ID buttons to set AM or PM; use the numbers to input the correct time. Then press #. Repeat for setting the day and press # again.
Aug 21, 2008 | GE 29871GE3 Digital Answering Machine
IN 120 base keeps flashing CL
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Jul 09, 2008 | Lands Phones
GE 25942EE-C model date time stamp
I cant program my phone.The CL light flashes and I cant do anything.
May 20, 2008 | GE 25942GE2 Cordless Phone System
GE CORDLESS PHONE ANSWERING MACHINE
The flashing CL means the clock on the phone has not been set. You can try to set the clock using the Menu option on the handset, but the easier option is to simply call the phone from another number. When this happens, the base of the phone gets a CID time and date stamp from the time calling, and the clock is set. You'll notice that the CL is no longer flashing after the phone has received the call. You don't even have to answer the phone- just let it ring once or twice and you're all aces.
Feb 26, 2008 | Uniden Cordless Phone
Set time and date?
I want to clear the blinking CL
Jan 22, 2008 | GE 25942GE2 Cordless Phone System
GE 25942GE2 Cordless Phone System Logo
462 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
