From the manual (http://www.lg.com/uk/support-product/lg-RHT498H#manuals_panel):
To reset forgotten password:
a) Display set up menu (see Displaying Set Up Menu)
b) Select lock system icon in left panel
c) Select Lock System from middle panel
d) Enter [210499]
e) Select displayed YES option
f) Press OK [ ]. Password has now been cleared.
It sounds like a mechanical fault. If the disc inserted is do not loaded properly into its drive mechanism, this kind of symptom can occur. Contact any service technician. Sometimes, a loose belt [at its disc loading section] might be the cause. Gopakumar Gopalan Google
I had mine for 2 years and within the first 12 months the tray would not always pop out when I wanted it to. Then finally the machine would not recognise the disc type. Its in getting fixed but although the dvd drive and associated pcb have been replaced the guy says it still can't recognise the dvd disc type. Still trying to work it out.
fitted a new drive in but it wont play normal dvds.
it recognises +- discs and formats them as it should
just need to work out how to make it play normal dvds.
dont want to pay for advise thanks
That is most common problem of DVD player recorder,when getting old cannot read DVD discs,only video cd and audio cd,sometimes does'nt read video cd also. The problem is in inside of the unit the DVD processor is defected already or maybe the solder is crack, need to resolder again or reheat the processor solder, or that processor change with a new one,so the performance will back again,good as new.The lense of that unit is good,i can assure that.
Been checking out my m/c and found that there are many -r & -rw discs the m/c does not recognise which gives rise to this problem. However the m/c does recognise VERBATIM discs and I have been able to record and dub to them with no problems.
