Question about Vizio L37 Television
Connecting an LCD TV to a computer to use as TV and Comp. Monitor.
I have a radeon x700 video card that has a monitor jack and a dvi i dual link jack.
The tv is a Vizio 37 inch with 2 Hdmi inputs, pair of component vid inputs, pc style vga input (1366x768 res), A/V input (composite and s video) .
I am wondering if I could connect the two and without sacrificing picture quality. Also, I'm not sure if a cable from dvi i dual link to hdmi exists.
Please help. Thanks!
  • Anonymous Mar 31, 2014
    New TV- hdmi port stopped working
Im no expert on the subject, but I use my L37 for a monitor, and use just the vga adapter. It works good as a monitor, and both dvds and my hdtv wonder tuner card look great through the vga connection. They do make adapters for dvi to hdmi. Although, hdmi also carries sound, but you wont get that out of your dvi output from your card. So you might not have sound when using that connection, as your tv may not look to the headphone type jack used for sound imput from your computer when you select the hdmi source on it. If you have speakers already connected to your computer you may not care. Also if you have a 720 p Vizio, 1366x768 is the highest resolution you are going to get out of it anyway, if I'm not mistaken. I'm Not sure why you would need 2 connectios to the same monitor either. I posted 1 link below because they had several dvi to hdmi adapters. Hope that helps.
http://www.bizrate.com/computercables_adapters/products__keyword--hdmi+dvi+d+dual+link.html
Posted on Aug 01, 2008
2nd monitor does not work with DVI to VGA converter cable. My video card has VGA and DVi ouputs.
The problem could be in the adapter to the video card. There are different types of DVI connections. If the adapter does not have the proper set of pins then the card will not recognize that a monitor is connected at that port. Monitors themselves have no bearing on whether a single or dual monitor set up will work or not. Digital Visual Interface Follow this link, it may help you determine if the adapter you are using is correct for the graphics card.
Apr 22, 2014 | Acer ET.CV3WP.E05 LCD Monitor - V193WEJb...
I have sapphire ati radeon 5570 graphics card. i have aoc 912sw+ 19 inch lcd monitor. how to connect hdmi port of graphics card with monitor?
the HDMI port is for connecting video and sound to a home theatre / surround sound system. I understand that this monitor only has a VGA connector.
The sapphire ati radeon 5570 graphics card has the following ports on the back to connect to a display: DVI (white), VGA (blue) and DisplayPort (the thin slot in the middle). You can use an ordinary VGA cable to connect the card to your monitor.
Unfortunately you cannot connect this card directly to your monitor using the DisplayPort.
Hope this helps
Tom
Jul 21, 2011 | AOC 912SW-4 Monitor
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Connecting PC to TV
you can only use your tv as your monitor by connecting a jack which is included on your video card. you can see on your cpu rear were located the video card interface. theres a hole circle on that with some slots. with use of the adapter came from your video card and a jack connecting to your tv, you can now see your desktop on the tv not on the monitor. hope that helps! pls do rate my post thanks!
CHARCOIS
Oct 11, 2008 | Connect3D Radeon X800 / 256MB GDDR3 / PCI...
Mag monitor doesn't display bios post
I have no experience with the DVI links because such technology is still unavailable here in Argentina. We have DVI video cards but finding a suitable DVI monitor is another (long) story.
I think that your card (that has 2 DVI ports) is initializing one port first (the primary one) and then, when windows starts, it initializes the other and outputs video from both ports.
Try connecting the monitor in the other DVI port.
If your card has a VGA output, the VGA gets initialized first.
May 06, 2008 | Computers & Internet
Triple monitor set up
That is because the tv is a connector for the tv only.. the other ones are for the computer monitor only.. you can only set up one at a time... If you want the tv one then only get the tv one to work...
Mar 24, 2008 | ASUS A9600GE/TD RADEON 9600, (128 MB)...
DVI connection
Did you try your monitor with another output (VGA)? If not, try it.
So, you have to check and make sure where the problem is (display card, monitor, or cable). Try with another cable or monitor. This way you will know where the problem is. If you don't have another monitor, try the monitor you have with build in VGA output on motherboard by taking the display card out.
Thank you,
Tan
Mar 04, 2008 | LG Flatron 295LM 22" LCD Monitor
Connecting a dvi-d cable from dvi-i graphics card to lcd monitor
i use a dvi connection on my computer.my lcd has many types of connectiond.i have to go to my menu on the lcd and choose what connection i using.maybe you have to do the same.
Feb 21, 2008 | Computers & Internet
Ati radeon 9600 video card
what you have the ATI card hooked up can you see the boot screen? If you can see that you might want to try going into safe mode and making sure your graphics settings aren't set beyond the capability of your monitor. If you can't see the boot screen then your card might be dead.
Apr 28, 2007 | ATI Radeon 9600 Pro 256MB DVI+CRT+TV 8X...
Vizio L37 Television Logo
576 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
