Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer timer
Is there any magic to install timer. I just install new timer and it only run from one place.Thanks
  • Anonymous Aug 29, 2008
    I have a Whirlpool Thin Twin. The washing machine does not complete its cycle. Is this a timer issue? Can I fix it myself?
  • 481 Answers
No magic to it, but double check your wire harness and make sure it is plugged in all the way. it is sometimes easier to plug the harness in before mounting the timer to the control panel.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 22, 2008
  • Mike Durland
    Mike Durland Jul 23, 2008
    • none of my free suggestions have helped you at all?
    •  if you feel the issue with the machine is something else let me know, i will try to help you figure it out.
    • a little more info would help
    Mike
  • Mike Durland
    are you sure that the old timer was bad?
Need new cycle control knob for Whirlpool Model LLR8233BNO
You can order replacement parts online. Here is a site that I have used in the past.
http://www.appliancepartspros.com/top-cabinet-parts-for-whirlpool-llr8233bn0.html
There is a place to search within this model and if you type "knob" without the quotes, it will show you just the knobs for the washer.
Oct 18, 2013 | Whirlpool 3362624 Washer Control Timer...
I have a Whirlpool Washer (Model: LXR6232EQ0). It will start washing & then stop. After pulling the timer out & pushing back in, the washer resumes operation. This happen 3-4 times per cycle. ...
You are correct in assuming that the timer is going out. It is fairly easy to replace, you simply take the upper back part off of the washer and remove the screws that hold the timer in place and reinstall the new one.
Mar 02, 2011 | Whirlpool Washing Machines
My whirlpool duet won't turn on. It stays in"control locked" mode and when I unplug and replug the washer in - it goes back to the same place. Is there a magic button to push or do I need a repair...
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
Whirlpool washer lsq9010pw -Timer not advancing
you can also check to see if the timer motor is good. not a good idea to bypass. if the presure switch was bad it would not stop filling up.
Aug 22, 2009 | Whirlpool Washing Machines
Water problem
Apr 01, 2009 | Washing Machines
I have a maytag washer (model LAT9416AAE). The timer motor doesn't run. If I plug it's wires directly into an outlet, it runs fine. In the timer assembly, it apparently gets no power. Is there another...
You need a new timer assembly. Please be very care full when hard wiring your machine. it could short the machine out and also cause personal and property injury.
Jan 07, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool 6th Sense AWM8123/1 error code FH
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.thank u....please rate it
Nov 28, 2008 | Whirlpool AWM8143 Front Load Washer
I have whirlpool washer model LSQ9549LQ2. It has burnt timer which I replaced. But now when I run washer it run only from one position from timer. Need help
Thanks for your question If your timer works in one cycle only say on the regular cycle You could have a defective one . If your washer has 2 speeds the delicate speed on your motor could be the problem
Jul 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II washer
If it will perform all of the functions if you turn your timer knob manually, I would open the console and check for any loose connections, although from your description your timer motor has gone bad (only availible as the whole timer) It can be purchased from online from the manufacture or from a local parts store.
Jun 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
