Question about Radio Shack Pro-97 Handheld Scanner
Won't scan frequencies.
Ok, this is an odd problem. Some days my scanner, when I press the scan button, will pick up all the frequencies I have, then sometimes it doesn't. I've adjusted the squelch, did everything I could. I've reset everything, re-entered the frequencies, and still, the same problem. I know that it's picking up the frequencies, because when I switch to manual, i can hear everything, but the moment I hit can, NOTHING. Any help would be awesome
Check the ATT settings ... when att is showing I don't believe the scanner is as "sensitive" as it is when ATT is showing  this is explained in the manual.... if I remember correctly it is toward the back of the manual Good luck
Posted on Aug 12, 2008
I recently purchased a Uniden bc345crs scanner. I programed 5 codes, but it will only scan one of the codes continuously. What do I need to do to have it scan the other programs? Thanks
Make sure you do have frequencys stored. Turn it on, push button to clock, then press bitton to scanner, then press hold, then the channel # you want it in, press hold again, now press e, enter frequency, press e again, if you want more channels press up, press e. Do this until channels are full or what you want. Then press scan if radio is ok it should scan.
Jan 24, 2015 | Uniden Radio Communications
How do I program a uniden BC 145xl base scanner
  • Press the power button to turn the scanner on.
  • Press "MAN" (for manual)
  • Now pick a channel where you want to store a frequency at and enter it on the keypad.
  • Now press the "MAN" button again to go to that channel.
  • Now enter the frequency you want into that channel and don't forget to include the decimal point.
  • Now press the "E" button (for enter) and you have programmed one frequency.
  • Repeat these steps until your scanner is programmed.
  • Now you can press the up and down arrow buttons to scroll manually through the channels or just press "scan" to scan through them.
  • Make sure to keep your squelch just above the noise so you pick up stations well.
  • Hope this helps.
Nov 24, 2011 | Uniden Radio Communications
How do I manually program frequencies?
  • Hi, i can help.
  • This scanner is pretty easy to program. Follow these steps ---
  1. First press the "MANUAL" button to stop the scanner from scanning.
  2. Now pick a channel you want to store a frequency on. For instance if the channel will be 15 the press the number 1 and then the number 5 and then press "MANUAL" again.
  3. Now enter the frequency you want to program and include the decimal point.
  4. Now press the "E" button to enter the frequency into that channel.
  5. Repeat them steps to fill up your scanner.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 19, 2011 | Uniden BC248CLT Base Scanner
Wont pick up any frequencies
Hi, my name is John. Try to program some frequency,s in it. Get them here. <a href="http://www.RadioFreq.com">www.RadioFreq.com</a> or <a href="http://www.RadioReference.com">www.RadioReference.com</a> ...instructions are #1. Press the E/PGM button. #2. Enter the frequency you want. Press the E/PGM button. #3. To program frequency, press the up- down arrow. #4. To exit, press the HOLD or SCAN button...... hope this was helpful....
Aug 27, 2010 | Uniden BC340CRS Base Scanner
HOW DO I PROGRAM THE CHANNEL IN AND LEAVE IT ON SCAN AND IT PICK THEM UP
To enter a known frequency into your scanner:
- Power the scanner ON
- Press the MAN key to stop scanning
- Press MAN repeatedly to select the channel to program
- Enter the desired frequency, including the decimal point
- Press E to enter your data into the scanner's memory
Repeat the process for other frequencies, and press the SCAN button when you're finished programming.
More detailed programming steps are presented in the factory operating manual, which you can download/print, free of charge, here:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
Aug 06, 2010 | Uniden BC60XLT Handheld Scanner
Where can i get the channel list for my eurovox EX5100 pvr blue
Hi, Please try the below mentioned steps: AUTO SORT OFF B4 U MANUAL SCAN A CHANNEL/S: Go into Menu / Installation / Fast Install and press OK (enter pin) Now press the red button on the remote for advanced install Scroll down the options and turn Fav Sort off then press exit (do not press OK) if you press OK all channel order will get sorted back to the default order MANUAL SCAN ALL CHANNEL?S: follow AUTO SORT OFF After you press exit you get a list of frequency?s press red button (update) to update all channels MANUAL SCAN ONE CHANNEL: On the channel that?s scramble press the info button twice and make a note of the frequency at the top left, now follow AUTO SORT OFF when u press exit u get a list of frequency?s scroll down till you get to the frequency you made a note of and press ok to tick the box then press blue button for manual scan else....do a factory reset on the box m8 then rescan for chanells then leave your box on sly sports 1 to update
May 19, 2010 | Computers & Internet
Am I able to scan a frequency band? for instance scan between frequency 150.200mhz and 160.200mhz? how would I do it?
Oddly, your scanner does not include this feature - which is standard on nearly all scanners. It does, however, let you search pre-programmed services (police,marine, etc.) or search up or down from a designated frequency. To do the latter:
1. Repeatedly press SCAN/MAN until MAN appears.
2. Enter the desired channel number you want to use as a starting point for the tune. Then press SCAN/MAN again.
3. Press TUNE/CLEAR to start tune. PGM appears.
4. Hold down the up or down arrow for about 1 second to tune up or down. The arrow appears and the scanner searches in the specified direction.
5. When the scanner finds an active frequency, it stops searching and displays the frequency.
6. To search for another active frequency, hold down
the up or down arrow for about 1 second.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
For a comprehensive database of active frequenciesn your area, visit:
www.RadioRefefence.com
BillB
Jan 12, 2010 | Radio Shack Pro-2018 Scanner
My uniden bc80xlt handheld scanner has lost all button functions. The radio still scans and picks up frequency broadcasts, but NONE of the buttons work. What is going on here?I have no" manual" function, I...
Sounds like you may have accidentally pressed the "LOCK" button. If there's a "key" icon showing, press the LOCK button at the bottom left of your keyboard, and hold it in until the icon disappears. In case you need it, here is a link to the operating manual for your scanner:
http://www.uniden.com/pdf/BC80XLTom.pdf
Nov 22, 2009 | Uniden BC80XLT Handheld Scanner
BCT 15 scans through to FM
the 2 buttons on top next to the display, 1 is for police, dot and the other button hp,bt. press them until all 4 pol,dot, hp,bt disappear on the bottom of the screen
Mar 24, 2009 | Uniden BCT15 Base Scanner
162.550 NOAA weather frequency
If your still having the problem, it could be that the transmitter for that freq lost some of it's power, so your scanner cannot pick up a clear signal. If everything else is working ok, that's my guess. Hope this helps,,, Mechanic
Nov 15, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-97 Handheld Scanner Logo
70 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
