Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I have whirlpool washer model LSQ9549LQ2. It has burnt timer which I replaced. But now when I run washer it run only from one position from timer. Need help
  • 943 Answers
Thanks for your question If your timer works in one cycle only say on the regular cycle You could have a defective one . If your washer has 2 speeds the delicate speed on your motor could be the problem
Posted on Sep 11, 2008
Washer fills with water but the timer is not moving
timer sticking if you can get at it spray the timer with wd40 penatrating spray or simmilar if that doesent work it the timer clock probably cheaper to buy a new washer than have this replaced hope this helps ivan
Sep 25, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
Whirlpool model LGB6000KQ1 gas dryer runs but has no heat only cool air. The timer when set to timed drying, moves down to off position, but does not shut off. Please let me know what parts may be faulty...
If the timer advances to OFF and does not stop you have a bad timer. It could also be the cause of no heat. Replace the timer first. If still no neat replace the glow bar ignitor.
Aug 24, 2009 | Whirlpool Dryers
Washer keeps running after cycle is over
it sounds like from what you have given me is that the timer could need replacing
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
Modle 80 washer question?
ck motor wiring connection for burnt or dark connections also possible bad timer ..have known timer to cause motor to run both speeds at same time this causes motor to overheat and shut off
Aug 16, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
128 people viewed this question
Dan Webster
Dan Webster
Sal De
