Question about Sony VAIO PCG-K35 Notebook
Overheating and ac adapter disconnection
My sony laptop heats to a vey hot temperature and seems bad. Is it just the laptop or is it a problem? 2nd, my ac adapter is loose when connected to the laptop and stops receiving power unless it is connected in a specific way.Some plastic in the socket is broken off.The ac adapter gets very hot(only where the laptop and ac adapter meet). My last problem is speed. my laptop slows down and it has plenty of room in the hard drive.
  • littleasian Jul 18, 2008
    were do i open to clean the fan? i am not very sure how to open my laptop and find the fan......
    Genius:
  • 2,028 Answers
O.k. Let's start by addressing the DC jack on the laptop. This needs replaced immediately, ASAP, do not pass go, (got the picture). With the jack being broken there is the very good possibility of creating an electrical arch which can do major damage to the machine. An arch can fry the motherboard and everything attached, hard drive, memory, wireless card, keyboard, and CD/DVD drive, leaving you a door stop with a good screen. Stop using it immediately until you get the jack fixed. Once you have the jack fixed I believe that your other problems will be cured also. The laptop overheating and running slow is from the machine starving for power and the hot power supply is from the backfeed at the broken jack.
Posted on Jul 18, 2008
    Problem Solver:
  • 5 Answers
Try to open laptop and clean the dust off the fan
Is there a software that is associated with my sonny battery that will make it charge again
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sep 14, 2011 | Sony VAIO PCG-K23 Notebook
    My dell inspiron 1501 won't charge when it's plugged in it works for awhile then it seem to loose contact and the battery runs down fast.
    Hello
    It would appear that there is a motherboard issue with this model laptop from Dell. Below is a link to the discussion thread for the problem you described. Unfortunately, there is no current solution for this issue - short of replacing the laptop.
    http://en.community.dell.com/forums/p/19092498/19363647.aspx
    Dec 03, 2009 | Dell Inspiron 1501 Notebook
    The Ac power supply on the motherboard gets hot and stops allowing the AC power to generate power and switches to battery and eats the battery power really fast. then won't charge until PC is completely...
    So the DC jack on the motherboard is Heating Up? I'm assuming the AC Adapter (charger cord) is also HOT...??
    Here's what your issue is:
    1. You're using the wrong volt/amp Adapter..(charger) For Example.. Your Laptop needs a 19.5v Adapter and you are using an 18.5v
    2. You're using a "generic" AC Adapter and Not an OEM one.. the generic adapters will overheat and sometimes even melt due to Cheap capacitors/resistors being used..
    3. You need to clean your Fan/Heatsink.. Clean the heatsink cooling fins to free blockage and stop overheating issue..
    Or .... 4. Possible faulty battery
    Nov 16, 2009 | Toshiba Satellite A75-S211 Notebook
    Today my cord for my toshiba was behind my pillow and i was lying on it. and I didnt notice, but then it showed that my laptop wasnt charging did my cord just get too hot? will it work later?
    The power adapter does not have a temperature sensitive device, therefore it won't stop for overheating if not in consequence of a fault.
    Try leaving the power adapter unplugged for about ten minutes.
    In the meanwhile also remove laptop battery and put it back.
    Connect it back to AC and laptop.
    Ensure that connection to laptop and power cord connection to AC adapter box are both well plugged.
    Before turning on laptop leave it connected for few minutes.
    If laptop still does not turn on and battery does not charge, then the AC adapter is faulty.
    A further test can be done using a multimeter to read voltage on AC adapter plug.
    A replacement AC adapter is not expensive and can be purchased online. Try entering in Google your Toshiba model followed by the words "power adapter".
    Aug 15, 2009 | Dell Inspiron 5100 Notebook
    Laptop shuts down and all lights incl ac adapter light goes out
    You can go into the BIOS and look for the temperature to see if in fact the system is overheating.
    Jun 15, 2009 | Intel Motherboard
    Ac adapter does not connect to battery
    You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
    1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
    2. Try removing your battery and using the ac adapter. If this works the battery is bad.
    3. Try a new ac adapter.
    4. Power supply is bad
    Jun 05, 2009 | Dell Inspiron E1505 Notebook
    AC Adapter melting
    It could be a fault with your laptop which is drawing more current than what the AC adapters can supply.
    OR
    The adapters are under too powered for your laptop.
    Check the voltage and current rating requirements of your laptop, this information is printed on a label on the bottom of the laptop.
    The adapter should have the same voltage and current rating or same voltage with a higher current rating.
    Jan 28, 2009 | Compaq Presario Notebook
    Laptop turning off
    Often, if a system turns off every time at roughly the same time, it's a hardware problem. System gets too hot, shuts down, restart it and it'll run again for a while, but not quite as long, and continue like that. Can you feel/hear the fan moving air? Possibly clogged, see what you can do to get it cleaned up a bit. Does it make any difference what surface it's on? May be covering a vent on the bottom or back.
    Oct 29, 2008 | Sony Computers & Internet
    Toshiba a105
    bad mother bord replace that bad power transiters on it not doing well and cpu getting hot may need new greese
    Jan 21, 2008 | Toshiba Satellite A105 Notebook
    Sony VAIO PCG-K35 Notebook Logo
    281 people viewed this question
    Top Sony Computers & Internet Experts
    Alun Cox
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
