Question about Cameras
Cannot eject card
My Canon Rebel Xti is a wonderful camera.  Recenty, the little button to eject my card is stuck in the down position and I cannot get my disk for pictures out.
Thank you for any assistance.  Gallt4@aol.com
I have the same problem and I am able to pull out the card with small needle nose pliers. Ian
Posted on Jan 26, 2009
    Novelist:
  • 142 Answers
I'm guessing this is a compact flash card since it is one of the more popular ones with an eject button. Fortunately the eject button is a mechanical type thing. These cards are only held in by friction, so what's required now is to simply pull out the card, but how can you do this without any way to wrap your fingers (or a small tool) around it?
There are a couple ways to do this... the way to do it and save the pics on the card is to take some 2 part epoxy (from your local walmart) and make a small batch (ie: less than 1/2 teaspoon). Epoxy two small screws to the card and let the epoxy harden for a day or so. Let it cure completely. Then pull on the screws and out comes the memory card.
The more risky way is to drill a VERY SMALL hole into the exposed end of the card (just barely enough to go through the case) and GENTLY insert a screw just enough so it grabs the plastic and pull out the card. If you don't drill in too far, the internal electronics won't be damaged and the card can be reused.
Good luck and please rate accordingly.
Posted on Aug 04, 2008
Eject latch for cf card broken
the eject button is broken on my xti camerqa. Can this be fixed and if so,how much to fix?? Thanks
Jan 10, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
My memory card just got stuck in my Canon Rebel XTi. The button to the side of the card is stuck down. Is there a back up release?
Repairing camera is a specialty. so unless you have this skill you'll have to let someone else fix it. i sent my camera to be fixed to: www.camerarepair.com they were reasonably priced and have a 6 month warranty. they're pretty quick also.
Jan 03, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My rebel xti stopped working in the middle of a photo shoot
I am wondering if you solved your prooblem with your camera, the same thing happened to me and I need it fixed for my daughter's birthday next week! HELP!
Sep 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
I have a Digital Rebel 40 D camera less than 1 year old and I removed the memory card and I cannot get it to go back into the slot. The eject button is still depressed after I depressed it to eject the...
im no expert, but i would use a flashlight to look inside the memory card holder and see if anythings messed up, and maybe jiggle the eject button a bit, and just maybe the button doesnt come up again until you push in the memory card. give it a little push they arent too terribly delicate. but make sure you are putting in the right direction. hope this helps
My Canon Rebel xti camera states that is an error with my compact flash, I bought a new one and it still won't work
Pull the cf card out and with a careful eye (maybe a small flashlight and magnifier) look down the slot and check to make sure none of the cF card receiving pins are bent... it happens and it'll give you a card error. Regretfully if this is the case, it'll need a repair, replacement parts are available but it is a little techie to get apart and swap parts... Check the pins... good luck on this..
Sep 08, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xti digital camera mem. card will not lock into place
It seems that the CF reader mechanical assembly part has loose or out of place an internal part.
It may be caused by excessive force in pushing/pulling a CF memory card, or due to a manufacturing issueof the camera.
The solution is to open the camera, and check what is causing the problem and fix it.
If it's under warranty, I do recommend you to return it. If not, then you will need to pay for its repair, or do it yourself if you have experience, skills and patience in fixing electronic devices.
Such repair will require some philips screwdrivers, a soldering iron, soldering wire, and a st of tweezers.
There are in internet some guides to open and disassembly Canon XT 350D or Rebel 300d cameras. The disassembly process with the XTi 400D is very similar. You can Google fr such guidelines.
Best regards,
May 24, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Memory card will not lock into down position. will just bounce back up
It seems that the CF reader mechanical assembly part is loose or it has out of place an internal part.
Best regards,
Auto focus suddenly stopped working
This may not be the same as your issue, but our AF stopped working as well. I tried all the recommended fixes - removing the card and battery, recharging the latter, removing the lens and cleaning the contacts, etc. None of those things worked. However, I then switched to MF, requiring me to turn the barrel, and I realized it was stuck and just needed a little force to get unstuck. Might have been the humidity. Anyway, our problem was solved - AF was back to normal after that.
Jan 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
CANON REBEL XTI LCD
Your battery is low ...shut the camera in off position and replace with fresh battery
Oct 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
New canon eos digital rebel xti
There have been several reports of CF cards that work with all cameras, except the Rebel XTi. It depends on the actual manufacturer of the card. Canon made a change mid-production that affected the data saving. Try another brand of card & you should not have that problem any more.
Jun 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Cameras Logo
150 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
