Question about Olympus VN-3100PC Digital Voice Recorder
32 bit into a 16 bit recording???
I have recorded loads of work onto this dictator and it is in a 32 bit format - (so I am informed when clicking on the properties of it).I am using it with the Dragon NaturallySpeaking voice to text software and to test my voice, it needs it in a 16 bit format.... PLEASE HELP! ???
Cheers, Ben
Try NCH Software's Switch freeware program. You can tell it to convert from one bit format to another even with WAV files (it will call them PCM, but Dragon recognizes them as WAV files). It is also the best batch WAV to MP3 converter I have found. I always download from the company's own site as other sites can attach viruses.
Posted on Aug 06, 2008
Can Google Docs transcribe something I've previously dictated and recorded on my cell phone?
Absolutely. It takes a little bit of setting up, but Google Docs can transcribe pre-recorded dictation. Here's an article comparing Google Docs to Dragon Naturally Speaking with pre-recorded dictation. Transcribe Recorded Dictation with Google Docs Low Tech Grandma
Here's another article comparing the accuracy of Google Docs to NaturallySpeaking: Dragon NaturallySpeaking vs Google Docs Low Tech Grandma
Nov 30, 2017 | Google Audio Players & Recorders
How do I change a 32 Bit to a 16 Bit?
Not only does the wav have to be 16 bit, it has to be PCM, 11.025
or 22.050 kHz, 16 Bit, Mono. I think it would be easiest just to play the audio from your sound recorder right into the microphone of your computer, since the Dragon software is especially made for listening on the microphone, Or hook up the audio out from the sound recorder to the Line-In jack of your computer using a male to male phono cable.
Jul 18, 2008 | Olympus VN-3100PC Digital Voice Recorder
How do I set my Tascam DP-32 to record 24 bit 48kHz?
Dustin, just go to song in the menu , click the arrow to song load, create etc. cursor to song create and it will give you the option of 16 or 24 bits just turn the cursor wheel then just cursor down with the button and select 44.1 or 48 kHz . Then cursor up to song load and push the right arrow and it will load your song with the settings you have selected. Very good recorder once you learn your way around on it. Joe
Nov 12, 2014 | Tascam DP-32 32-Track Digital Portastudio
What is a dictation system?
Wikipedia: Digital dictation is a method of recording and editing the spoken word in real-time. The recording is done by the use of a digital recorder. Digital recorders are lighter have a longer battery life and are able to record a for a lot longer utilizing the same media, as compared to analog tape based dictation machines. The files generated with digital recorders vary in size(kilo bites or mega bites) depending on the manufacturer and the format the user chooses. The most common file formats that digital recorders generate have following extension WAV, WMA, and MP3 true dictation machines record in the DSS and DS2 format.
Jan 24, 2013 | Office Equipment & Supplies
My ds3000 dictation machine wont work with vista
The DS-3000 and the software is was shipped will not operate with Windows Vista. The software i suspect you have will DSS Player Pro Release 2 or 3. If you obtain a copy of DSS Player Pro Release 4 you will be able to use the DS-3000 on Windows Vista 32 bit or 64 bit without problem.
Jul 12, 2009 | Olympus DS-3000 Digital Voice Recorder
Which recorder is the best
you will need to change the format of the files by using sound recorder in windows xp. just open the file and save as cd quality format. this will change the bit rate to 16 bit needed to make a cd
Jan 23, 2009 | Olympus VN-3100PC Digital Voice Recorder
Olympus DS-5000 pro software issue
No, there is no way to change the record format to dss classic. However, with the pro software, you can set it to automatically convert to dss upon download.
Dec 22, 2008 | Olympus DS-2400
Olympus VN-2100PC
the file from the recorder is in a 4 or 8 bit format... use sound recorder to convert to 16 bit format
Aug 02, 2008 | Olympus VN-2100PC Digital Voice Recorder
Audacity
Use Sound recorder that is included on Windows XP it gives the easiest conversion option for .WAV files.
Converting the File Properties
1. Left click Start, Programs, Accessories, Entertainment, Sound Recorder. If you
intend to do this procedure often it is recommended to drag the Sound Recorder shortcut
icon onto your Desktop for convenience.
2. In the Sound Recorder box click on File> Open
3. In the Look In field locate and select your file. Click Open.
4. The Sound Recorder box is back. Click File> Save As.
5. In the Save As box click Change…
There are all the options listed that you can change and the bit rate is one of the options.
Jul 19, 2008 | Olympus VN-3100PC Digital Voice Recorder
WS-300M Olympus Voice Recorder
you can rewind a tad and listen, but you can't overrecord, because a digital recorder writes audio information into a data file and saves it. you just can play it back again and record a new file. if you want to cut off a part of your recording, you have to edit the file in an audio editor. - as the olympus stores wma-files, you'll have to convert them into wav format first to edit them. i tried the 'switch' software successfully.
Aug 13, 2007 | Olympus WS-300M Digital Voice Recorder
Olympus VN-3100PC Digital Voice Recorder Logo
131 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
