Question about Olympus VN-3100PC Digital Voice Recorder
How do I change a 32 Bit to a 16 Bit?
I have recorded loads of work onto this dictator and it is in a 32 bit format - (so I am informed when clicking on the properties of it).I am using it with the Dragon NaturallySpeaking voice to text software and to test my voice, it needs it in a 16 bit format.... PLEASE HELP! ???
  • 4 more comments
  • Ben Jacobs Jul 18, 2008
    Right... the dragon software is meant to be great, just want to work out how to use it!
    I have still not been told how to sort it? Only a link to an instruction manual.
    Cheers, Ben
    It still needs to be a .wav document..... Cheers
    What is this supposed to tell me?
    This came with the product.
    Cheers, ben
    Any other ideas... It must be simpler. Someone must haver used this software with this hardware before... No?
    These are too complicated, I have downloaded all of the software you have stated and am not getting anywhere with it. I just need to convert the 32BIT .wav file of my audio piece into a 16BIT .wav file so that I can load it into the dragon software which will convert it into a text document.
    Cheers, Ben
    Brigadier General:
  • 6,966 Answers
Use an MP3/WAV (Audio) Mixer/Converter program like Acoustica or checkout this page. Open your .wav file (32 bit). Click on File, Save as, Wav file, type in new name, Save button, next window will be asking you properties of new to be save file (sample rate and how many bits). This will give you the option to save in
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 19, 2008
    Master:
  • 788 Answers
I think Audacity would be the way to go. Just download it and load up your file. Then do an export and chose the format you need. Get it here: http://audacity.sourceforge.net/ and check this out: http://audacityteam.org/forum/viewtopic.php?f=11&t=5135 and http://audacityteam.org/wiki/index.php?title=Bit_Depth.
Posted on Jul 18, 2008
    Scholar:
  • 101 Answers
Not only does the wav have to be 16 bit, it has to be PCM, 11.025
or 22.050 kHz, 16 Bit, Mono. I think it would be easiest just to play the audio from your sound recorder right into the microphone of your computer, since the Dragon software is especially made for listening on the microphone, Or hook up the audio out from the sound recorder to the Line-In jack of your computer using a male to male phono cable.
  • Jerrod J
    Jerrod J Jul 18, 2008
    Plan B: Go get your pair of ruby red heels, click them together, and say "I wish this was 16 bit PCM 22khz audio format" three times. =)
  • 818 Answers
Ftp://ftp.scansoft.com/nuance/dns9/dns9_usergd.pdf
see this
Sergio
    Genius:
  • 1,665 Answers
Take a look at link also:
http://search.wareseeker.com/convert-a-32-Bit-to-a-16-Bit-digital-voice-recorder-a/
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jul 18, 2008
    If there were only a few files I would use Audacity, because I already have it installed on my PC.
    In Audacity, look in Edit > Preferences > Quality
    It says 'Uncompressed Export Format', make sure it's set at WAV(Microsoft 16 Bit PCM).
    Also make sure that 'Project rate' (in bottom left hand corner of screen) is set to 44100.
    Then I would import each WAV file and straightaway export it as WAV. They will be exported as 16 Bit.
    But if there are a large number of files maybe someone will suggest something less labour-intensive
    http://ubuntuforums.org/showthread.php?t...
  • 6,487 Answers
IF you really want to learn how to use the Dragon software check this link and read the user manual for it ftp://ftp.scansoft.com/files/support/manuals/dns8_usergd.pdf
Hope that helps...........
  • Olympus Master
  • 19,396 Answers
32 and 16 bits should be compatible, I will check if there is a format converter for the files.
  • 6 more comments
  • Ginko
    Ginko Jul 18, 2008
    Here you go:
    Download the audio files into computer.
    Make a backup copy of files , just in case.
    Install this audio converter software, and use it to convert from 32 to 16 bits .
    Ensure you set conversion from 32bit to 16 bit in converter software settings
  • Ginko
    Ginko Jul 18, 2008
    There is more audio converting software available. The one provided is free, if it does not work there are more free software package, or pay-for versions starting from under $20.
    Let me know if you have troubles with the software above. It should be ok.
  • Ginko
    Ginko Jul 18, 2008
    Link to manual? that was a link to a download. : Download LS Encoder
    download the software , the software converts files, including WAVs from 16 bits to 32 bits, is not what you need?
    Just install encoder.
    copy files into PC
    encode files
    load files back.
  • Ginko
    Ginko Jul 18, 2008
    This is easier to use download this.leave the one above:
    Download wavelab lite free software - Downloads Free - wavelab ...
    If you cannot use the above click on download a different software
    No matter what software you use , you need a audio file converter.
    Here you can download a good software trial.
    Unfortunately many of this software suites are not easy to use, you will have to play with them.
  • Ginko
    Ginko Jul 18, 2008
    You dont use the software on the olimpus, you download file , convert them using a computer, then upload them on the Olympus.
    There is no conversion software working directly on the Olympus.
    .Download free Wavelab 5.0 I remember it was quite easy to use. The other ones above are more difficult.
    1. Install wavelab
    2. Download audio files in PC
    3. Load audio files in wavelab
    4. Save file from wavelab setting format to 16 bit in file properties.
    5. Load back up to Olympus.
    Not too complicate, other programs above are more difficult.First one posted save in mp3 no good.
  • Ginko
    Ginko Jul 18, 2008
    I do not know if you are reading my posts, I hope you have enough information, let me know if you need further help
  • Ginko
    Ginko Jul 18, 2008
    Well, what you do need to do:"just need to convert the 32BIT .wav file of my audio piece into a 16BIT .wav file" requires one of those software.
    But if you know better than my why ask.
    If you want use wavelab : Wavelab 5.0 to do the conversion , it is the easiest to use .
    If you re record with a microphone and a jack the quality will be bad.
    Do as you like.
  • Ginko
    Ginko Jul 19, 2008
    I can see you are still in trouble. If you had been able to use any of the software above I found a much easier one.
    This is only converter, no additional features.
    It is converter only.
    Here is main window:
    At start click option, then click Wav, then set to 16 bits like in pictures:
    Then you load files and convert:
    All you have to do is (1) Load files
    (2) file appears in list
    (3) set output to Wav
    (4) press start, files are saved automatically.
    Important set option button to wav 16 bit output at start.
    Cannot find anything simpler than this, it is demo version will last 30 days or so.
    You can buy full version for $24 here.
    For the free trial do the following
    Install from here download From Local1
    Or from here
    download From Local2
    Don't forget to rate the solution
2 Suggested Answers
SOURCE: 32 bit into a 16 bit recording???
Try NCH Software's Switch freeware program. You can tell it to convert from one bit format to another even with WAV files (it will call them PCM, but Dragon recognizes them as WAV files). It is also the best batch WAV to MP3 converter I have found. I always download from the company's own site as other sites can attach viruses.
Posted on Aug 06, 2008
How do I set my Tascam DP-32 to record 24 bit 48kHz?
Dustin, just go to song in the menu , click the arrow to song load, create etc. cursor to song create and it will give you the option of 16 or 24 bits just turn the cursor wheel then just cursor down with the button and select 44.1 or 48 kHz . Then cursor up to song load and push the right arrow and it will load your song with the settings you have selected. Very good recorder once you learn your way around on it. Joe
Nov 12, 2014 | Tascam DP-32 32-Track Digital Portastudio
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
How can i change display settings of my lap top to true color 32 bit
Right-mouse click anywhere on the desktop "wallpaper".
Click Properties.
Click Settings.
Change from 16-bit or 24-bit to 32-bit.
Click Apply.
Sep 13, 2010 | Computers & Internet
My ds3000 dictation machine wont work with vista
The DS-3000 and the software is was shipped will not operate with Windows Vista. The software i suspect you have will DSS Player Pro Release 2 or 3. If you obtain a copy of DSS Player Pro Release 4 you will be able to use the DS-3000 on Windows Vista 32 bit or 64 bit without problem.
Jul 12, 2009 | Olympus DS-3000 Digital Voice Recorder
Themes are not working
I can just guess , as there's not much information, I wonder if you have changed the graphics adapter settings from 32-bit to 16-bit ? or have chosen an alternate theme ?
right-click desktop and select personalize
click window color and appearance
click open classic appearance
select scheme and apply .
if you have a independent graphics card please go into the menu and make sure it's set at 32 bit color . good luck
Apr 15, 2009 | Microsoft Windows Vista Ultimate Edition
Which recorder is the best
you will need to change the format of the files by using sound recorder in windows xp. just open the file and save as cd quality format. this will change the bit rate to 16 bit needed to make a cd
Jan 23, 2009 | Olympus VN-3100PC Digital Voice Recorder
I just bought a 64 bit operating system Vista Home Premium Computer and it won't load a 16 bit software application. Is this normal? Is there anything I can do to my computer to change it from a 64 bit...
You can try running the 16 bit app in compatibility mode. Right click on the app's exe, click on properties, and select compatibility, then tick the box labeled "run in compatibility mode", then select Windows 98 from the now available drop down box.
Dec 25, 2008 | NewTek Video Toaster 2.0 (512 MB) Graphic...
Olympus VN-2100PC
the file from the recorder is in a 4 or 8 bit format... use sound recorder to convert to 16 bit format
Aug 02, 2008 | Olympus VN-2100PC Digital Voice Recorder
Audacity
Use Sound recorder that is included on Windows XP it gives the easiest conversion option for .WAV files.
Converting the File Properties
1. Left click Start, Programs, Accessories, Entertainment, Sound Recorder. If you
intend to do this procedure often it is recommended to drag the Sound Recorder shortcut
icon onto your Desktop for convenience.
2. In the Sound Recorder box click on File> Open
3. In the Look In field locate and select your file. Click Open.
4. The Sound Recorder box is back. Click File> Save As.
5. In the Save As box click Change…
There are all the options listed that you can change and the bit rate is one of the options.
Jul 19, 2008 | Olympus VN-3100PC Digital Voice Recorder
Jul 18, 2008 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-3100PC Digital Voice Recorder Logo
118 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
