Question about Garmin GPS
When I try to charge my garmin nuvi 200, it turns on and displays the garmin screen, then shuts off and turns back on. If I unplug it and try to turn it on manually, it won"t do it, because it won't charge no matter how long I have it plugged in. This problem was totally out of the blue.
  • ajjr10 Nov 29, 2008
    sam problem
Mine did the same thing and Best Buy informed me that I would have to send it to Garmin.
Posted on Jul 30, 2008
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuviĀ® 200 Car GPS Receiver
My Nuvi 200 screen went black. I've tried turning
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Oct 28, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 not charging
I also have a Nuvi 200 that didn't charge. The problem is the charging port disconnected from the circuit board. You can disassemble the unit and reconnect the charging port but it takes a small torques wrench and a small screw driver. You will also need a soldering iron preferably with a fine tip and a very steady hand. Good luck.
Sep 24, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 260W shuts off before it fully loads maps
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 19, 2009 | Garmin nuvi 260W GPS Receiver
New Nuvi 200 will turn on briefly then turn off.
You need to charge your gps from any external charger and check whether screen is working properly .
Also do firmware update for your gps .
By updating firmware your problem can be fixed .
Jan 22, 2009 | Garmin nuvi 200W GPS Receiver
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
I try to turn on my garmin navigations system and it will not turn on. and i need to get some were.
I try to turn on the Garmin Nuvi and it will not go on. You can move the bottom to the on position but it just will not turn on. But when i charge it you can see the Garmin Nuvi on the screen and you can tell that it is charging. Please help. The model is Garmin Nuvi 750.
Bambi66
Oct 16, 2008 | Garmin GPS
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
My Garmin Nuvi 200 wont turn back on
Our Garmin didn't turn on. We unplugged it, pushed the reset button on the bottom and then plugged it in again and it WORKED
Aug 02, 2008 | Garmin nuvi 200W GPS Receiver
My Garmin nuvi 200 stoped working so I went to get new batteries for the cord. They tried to replace them but the Garmin still did not work. They sold me a universal cord with a plug that goes with the...
I had the same problem with my Nuvi 760 turning itself off right after the "Loading Maps..." screen but I found the answer in the Q&A section on Garmin's website.  It's actually very simple and you'll kick yourself...  Charge it up all the way!  It does that when the battery is really low.
Apr 16, 2008 | GPS
GPS Logo
341 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
