How do i reset my ravenheat boiler as the pilot light has gone out
  • 1,420 Answers
Follow this link to the user manual page and select which model you have. Follow procedure in User Guide. http://www.ravenheat.co.uk/Userguides.htm
Posted on Jul 21, 2008
My ravenheat boiler wont fire up it clicks a few times and stops
check blower motor may be off on reset mode or capacitor may have gone bad didnt specify which model the following link click on your model the manual has a troubleshooting guide for assistance
Ravenheat
Aug 30, 2016 | Heating & Cooling
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Got a ravenheat ls 1oot combi boiler not working red light on timer on not making any noise works every now and then for short periods
I have a ravenheat 820/20(t) boiler and the pilot will not say alight, I have 20mV from the thermocouple(through the safety switch) and its had a new gas valve fitted(good earth continuity).The heating system is holding pressure at 1.2 bar.
Has anyone got any ideas what could be holding the pilot 'OFF'.
I CANNOT SEE ANYTHING ELSE IN THE PILOT CIRCUIT.
PLEASE HELP !
Dec 20, 2009 | Water Heaters
Ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
How do you light a ravenheat pilot light
push in the yellow or grey button on the gas valve and click the piezo ignighter repeatedly keep the gasvalve button depressed for 20 seconds and the boiler should light if it does not you have a fault come back for more advice if this happens
Sep 30, 2009 | Calvin Klein The Field Controls Company...
I have an old ideal elan 2 boiler. The pilot light has gone out and wont re-ignite. I have pressed the ignition switch in but there is not even a spark. Does anybody know where the re-set button is on...
Hi, to light the pilot you must first ensure the gas valve button (Grey with 3 symbols on it) is placed in the ignition position, then, while holding the button in towards the gas valve depress the orange ignitor button several times, hold the gas valve button in for about 30 seconds once the pilot lights. If it fails to light and you cannot see a spark when you depress the ignition button the cable could be faulty, the ignitor corroded or damaged or the pilot could be blocked or the gas turned off. If it is an Elan 2 CF boiler there is no reset button.
Apr 26, 2009 | Kitchen Appliances - Others
My Ravenheat LS80 won't give me hot water!
years after the problem..... i find this link. relevant for future people i suppose and definately better than the previous answer which is not applicable at allravenheat.co.uk/pdf/manuals/LS80printV3.1.pdf
Apr 11, 2009 | Water Heaters
I have a ravenheat boiler that i have no idea hoe to reignite
you need to reset it but if it dont light you prob have rectifaction fault
Feb 15, 2009 | Calvin Klein The Field Controls Company...
Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
Oct 25, 2008 | Water Heaters
Heating & Cooling Logo
1,056 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
