Konica error code
Error code F-35-9.
  • 42 Answers
F-35s are fixing unit problems in alot of Konica's.Need model to know for sure.
Posted on Jul 19, 2008
Konica error 35
Error F35 for Konica seems to be "low fuser temperature" error.
Could be a sensor or the fuser unit itself.
You should also try turning off the unit for about 10 minutes (unplug) and then restart it.
Apr 08, 2014 | Office Equipment & Supplies
Error code 35
error code 35?
error codes on the minolta print /copy machines usually have a letter followed by four digits e.g. C2035,
please indicate which model and exact error code with a description of the error as seen by the user.
Sep 25, 2013 | Konica Minolta Office Equipment & Supplies
Sir, i have Konica 7145 machine. i have any 10 mints after F-35-3 error, or some time F-35-9 eroor
Hi the error codes you are getting f-35-9 and f-35-3 are common error codes for this machine
First do not reset the machine using 25 dipswitch 3-1 until you resolve what is wrong
The errors are related to the fuser unit assembly parts f-35-3 is the th1 thermistor f35-9 is also an issue with th1
I can tell you that the thermistors th1 and th2 have been changed a nuber of years ago you will need to replace them both also any other parts in the fuser like the web upper and lower clas adn rollers busings ect there is a fuser kit that you can purchase from konica it comes with all the parts to replace on the fuser unit
when replacing the parts on the fuser unit this must be done by a certified technician only if you are not trained to do this leave it alone
The best option is to replace the fuser unit assembly and have it installed by a certified engineer you will save a lot on labour
Once the new unit or refurb unit is done you will need to switch of machine hold down 2 and 5 at the same time switch on the machine and then go into dipswitch 3-1 and change from 1 to 0
Jan 20, 2011 | Konica Minolta Office Equipment & Supplies
F-35-4 this is over problem
Fuser error: lamp, thermistor, fuse problem, etc. Part needs to be replaced and code reset in service mode only. Call a tech
Jun 20, 2009 | Konica Minolta DiALTA Di200 Copier
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
Error code f35
konica f 35 eror code
Aug 06, 2008 | Office Equipment & Supplies
Error code f-35-8
On most Konica copiers, an F35 error indicates:
1. low temperature of the fuser; and/or
2. open lamp; or
3. open thermo wire fuse; or
4. open thermistor; or
5. or anything heat related at start or warm up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Office Equipment & Supplies
Konica 1112 Error code 35
The procedure is as follows:
1. Turn machine off.
2. Turn machine on while holding the 2 & 5 keys.
3. Enter 47 on the keypad.
4. Press the Stop/Clear.
5. Enter 0 on the keypad.
5. Press the START PRINT button.
Power the machine off and on to exit the service mode.
You're done!
Mar 26, 2008 | Office Equipment & Supplies
Error F-35-4
problem konica F-35-4
Oct 15, 2007 | Office Equipment & Supplies
131 people viewed this question
jasbo
jasbo
