Question about Epson Stylus Photo R1800 InkJet Printer
Dirty printouts The print quality is fine but there are faint black marks/lines down both sides and in the middle of the paper. I've never had this problem before. I looked in the manual and could find nothing. Perhaps it needs to be cleaned? But manual says, "Clean ink out of printer's interior with soft, damp cloth. Fine, but what part of the interior? How do I do this without touching the gears?
  • Epson Master
  • 691 Answers
Don't worry too much about touching the gears. As long as the machine is unplugged with the head away from the home position you can clean all the rollers etc with Windowlene (Windex) liquid sprayed onto a cloth.
There is a sponge pad that runs the width of the machine just under where the print head travels back and forth. VERY CAREFULLY remove the pad, noting it's orientation and where the tabs locate it. Do not pull too hard when you get to the tabs. If you pull them off the pad will not sit properly and may make contact with the back of the paper.
Remove the pads and rinse it in warm soapy water in a metal or porcelain sink - plastic sinks may be stained by the ink. Allow it to dry naturally and don not wring or squeeze it as you may deform it's shape.
While the pad is out take the opportunity to clean as much of the inside with Windowlene and cotton buds taking care to wipe off any liquid you move around. When reassembled, run several blank A3 sheets through the machine to soah up any blots you may have missed.
You may fins that after this the marks are still apparent on the print. If the lines are coloured or black "drag" lines then read my previous posts on underhead cleaning. It is fairly common for dust balls to get caught under the print head. My underhead cleaning will help to remove those. Read it HERE.
If the marks are like a perforations, then you need to look at the pin wheels on the exit side of the printer. You may need to adjust these up a little by manual methods i.e. pull it gently
Posted on Jul 18, 2008
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
Dear Sir, i have buy hp laser jet p1007 printer but it gives no quality. it gives faint print and when i give pdf file print command it give very faint print so what can i do. Thats the faint...
Hello and Welcome to FixYa!
Hmm, faint printout may occur due to so many issues, like paper quality, bad connection, bad/dirty pick-up roller, wrong settings...
To counter all these issues, writing all the text here will be difficult and will decrease the understanding quotient. So I'm attaching a link below, where you will find all the possible solutions with pictorial / graphical representations, I hope you will find it helpful and will definitely come up with some solution.
In Case you are having any issues/questions, do ask me. I'm here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Resolving Print quality issues
Aug 09, 2010 | HP LASERJET P1006 Printer
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP 1610 printer
It occurred to me when I was reading your post that photo paper has printing and non-printing sides. If the paper is loaded upside down, it's printing on the non-print side, which would result in what you're seeing. It's just a hunch, but you might want to consider it.
HP.com has a web page that will walk you through the process of checking on this and other potential problems.
Checking image quality problems
Hope this helps. Good luck.
Oct 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Epson Stylus Photo R1800 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
