Question about Acer Aspire 1200X Notebook
Windows preview on taskbar
I tried to use the windows preview on the taskbar only to find the button you tick has been grayed out. i have been able to use this in the past. i have windows vista home premium
    Genius:
  • 2,028 Answers
Do a system restore to a point that you recall this working properly.
Posted on Jul 18, 2008
Move taskbar to bottom
Click and drag
Click in the middle of the task bar (your's is on right side of screen), and drag to the middle of the bottom of screen and release button.
Aug 31, 2014 | Microsoft Windows 7 Home Premium 64 Bit...
Tip
HOW TO ENABLE PREVIEWS FOR INDIVIDUAL TABS ON FIREFOX 3.6 IN WINDOWS 7 TASKBAR
It applies to : Firefox 3.6 : Windows 7 Home Premium: Professional: Ultimate: Enterprise
Run Firefox and type about:config in address bar and press enter, it will confirm about changing these advanced settings ….etc. Just click on I’ll be careful, I promise!
Now double click on browser.taskbar.previews.enable to set it to true Or right-click on it and select Toggle. It’ll set its value to true.
Close Firefox and re-launch and you will see separate previews for individual tabs on Taskbar.
on Jul 03, 2010 | Computers & Internet
Delete aero peek
- right-click on Taskbar
- select Properties
- uncheck Use Aero Peek to preview the desktop
May 11, 2014 | Microsoft Windows 7 Home Premium 64 Bit...
How to delete AERO PEEK from taskbar option grayed
Click on Start, then type in Visual effects, click on Adjust appearance and performance of Windows and then uncheck the Aero peek checkbox.
Feb 14, 2013 | Microsoft Windows 7 Home Premium 64 Bit...
When i turn on its taking time to get my disk that is my proplem
the best way is to upgrade ur PC , or format your harddisk or apply this settings as follows ===
Speed Up Windows 7 Boot Up Time Don't Try This To Make Windows 7 Faster:
Try ReadyBoost:
  • 1. Speed Up Windows 7 Using ReadyBoost
  • 2. Check ReadyBoost
  • 3. Speed test your SD Card, CF Card, Flash Drive, HDD
Speed Up Windows 7 BootUpdate 04/21: This tweak does not seem to have great effects on your boot time. Instead use a startup programs manager for Windows 7 and remove as many startup programs as you possibly can.
Do you have a dual-core or quad-core processor? Great, let's lower the boot time of Windows 7:
1. Click on Start, enter "msconfig" into the search field
2. Open the "boot" tab
3. Click on Advanced
4. Check "Number of proccessors" and select "2′ or "4′ from the dropdown menu. (obviously, you can only select it if you have a dual-core/quad-core).
Full Image
Speed up Windows 7: Change Taskbar Thumbnail Preview Time1. Click on Start, enter "regedit" into the search field.
2. Goto: HKEY_CURRENT_USER\Control Panel\Mouse
Speed Up Windows 7 Taskbar Thumbnail Preview
3. Double-click on "MouseHoverTime" and change the value to 100 or lower:
Change the mouse hover time to 100 or lower
4. Voilà, your thumbnail previews should appear a lot faster now. For another great tweak to speed up the Windows 7 taskbar, click here.
Speed Up Windows 7 Shutdown Time1. Open the registry editor (enter regedit into search field)
2. Go to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control"
3. Lower the value (12000 is the default value = 12 seconds) to a value of your choice
Speed Up Application Access - Increase your productivityFirst of all create a folder "QuickStart" somewhere on your PC. Right-click on your taskbar:
toolbar.jpgLocate the folder "QuickStart" (you just created the folder so yo should know where it is) and then click "Ok". You are almost done, but we don't want that ugly text on our taskbar that is using a lot of space, turn it off:
texttitle.jpgRight-click on the new toolbar and uncheck "Show Text" and "Show Title"! Now drag the toolbar to the left until it's below the main icons and you will have something like this:
Sep 01, 2011 | Acer Computers & Internet
Using Word 97. Applied a background (marbled gray)to a document. Saved and printed. Background is not printing, nor showing on Print Preview?
To print the background in your document, do the following:
1) Open the word document and go to File->Print.
2) When the print window comes up, click the option button at the bottom.
3) Then,tick the Background colors and images as shown in the attach picture.
4) Click OK.Then Click OK again to Print.
Feb 06, 2011 | Computers & Internet
Black on two sides of monitor
For the Start menu, I assume you're talking about the taskbar that appears on the bottom of the screen. Press the Windows button on the keyboard (usually located between the Ctrl and Alt button on the left hand side).Right-click on the Start button. Click on the Taskbar tab and check the box that says "Lock the taskbar". Your taskbar should return to your desktop.
Wallpaper (desktop image)
In XP:
Right click on a blank space anywhere on the desktop. Click on graphics properties. You should see a window with your Wallpaper previewed in the top window. Click in the Settings. There should be a setting for "Stretch". Select Stretch and your desktop should return to normal.
In Vista: Right click on a blank space on the desktop, click personalize/display settings/advanced settings Click on your graphics card if available or graphics properties. You're looking for Aspect Ratio options From here you will see a setting with 2 options
  1. Maintain aspect ratio
  2. Full screen (no border)
Depending on your graphics card, this process may differ slightly, but the setting you need is Aspect Ratio
I hope this answers your questions. Best of luck.
Greg
Jun 15, 2009 | Compaq (388110-001) Pentium III, 450 MHz...
My taskbar doesn't show window preview
Did you install Vista yourself? Coud you have installed Vista on a PC that is not Vista ready? Most likely problem is that your video card is not supported for the preview feature of Vista. However, if you are sure that your video card is Vista compatible then you might need to find the latest (Vista compatible) driver for your video card. I once upgraded a video card driver to find that it suddenly supports Vista window preview function.
Apr 19, 2009 | Microsoft Windows Vista Ultimate Edition
My taskbar option is not working
Did you right-click on the Start button and go to properties>taskbar page and check to see that the "Show Windows Preview" box is checked, under "Taskbar appearance"?
Apr 12, 2009 | Dell Inspiron 1525 Notebook
Acer Aspire 1200X Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
