Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher&Paykel model GW711 top loader draining water onto floor in between wash and rinse cycles Gday, our top loader GW711 is filling and completing what seems to be the initial agitation cycle but when it shifts to the drain stage it's draining water directly onto the floor Have checked all hoses and they all appear fine.
  • 9 Answers
Why life so unfair ?
Posted on Jan 27, 2011
SOURCE:
Fisher & Paykel gw711 excellence keeps filling and overflowing
the clear pressure tube is blocked,
you need to blow air down the clear pressure tube hose.
Jan 30, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL15 washer stops during wash, beeps, and displays the 3rd, 6th, and 8th lights. The problem began intermittently about a week ago; however, powering off, changing the cycle, and...
Hi just read your posting.Now error code 37 is called pump block error.This means either your drain pump is jammed, or the drain pump is blocked or the pressure switch tube that regulates the water level is kinked or blocked or the motor controller is faulty.Does your machine always drain the water?Please reply and let me know if your machine is draining the water and we can track the fault down.Looking forward to your reply.
Sep 16, 2010 | Fisher Paykel EcoSmart GWL15
We have a fisher and paykel gw711 washing machine that continues to fill with water while it is in the rinse and spin cycle
Hi Robbie just read your posting.Now just a couple of questions.Does the machine keep filling and flood?Can you manually select the amount of water for the wash --eg-- low, medium,or high?Or does the machine drain and fill at the same time?Please reply with additional information on the questions and I am sure I can rectify this fault for you.
Jul 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water runs continuously tub never fills My Fisher & Paykel top loader keeps filling and draining at the same time. It never gets full of water. The hose is way higher than the machine, but still drains...
where is water draining into? have u got grey water hose attached to it?make sure u can see end of drain hose, put into bucket at lid level, if it still drains as it fills u have a faulty control module.please reply for more help
Apr 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
515 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
