Question about Lexmark All-in-One Printer with PictBridge
Lexmark 2500 I succesfully installed this printer program to my windows xp computer. The program runs, but when i try to scan or print it tells me unable to communicate with the printer. I have tested the USB cable, changed ports, unplugged and replugged each cord (power and usb) reinstalled the software, and it still is not connecting. Are there any other suggestions.
  • 3 more comments
  • cisneros0300 Sep 23, 2008
    i have the exact same problem
  • twhizzy23 Oct 05, 2008
    scanning won't wokrk
  • Anonymous Oct 28, 2008
    I have the same issue. Lexmark support told me that I needed to update the drivers for my usb ports. WTF! They all work on other devices. F.U. Lexmark.
  • ladama2008 Jan 05, 2009
    I have the same problem
  • Anonymous Mar 28, 2009
    I have the exact same problem. I bought my laptop and printer at the same time. My printer has never scanned anything because the imaging studio software won't install for some reason.It prints and copies but it won't scan because I don't have the imaging studio!
I need a lexmark 2500 imaging studio...can anyone help me?
Posted on Aug 03, 2008
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
My lexmark x2670 prints copys but it will not scan a document ocr it scans but will not process it .,then tells me it needs a program that has been deleated or lost i am using vista 32bit noel
You will need to update the printer software installed on your computer to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. Just re-insert the install disc into the computer hard drive and run the installation setup.
If you lost the disc, please contact Lexmark Technical Support Center for assistance.
Aug 10, 2011 | Lexmark X2670 All-In-One Printer
I give the order print and nothing happenes
Have you tried disabling the anti-virus, will it print? If not, uninstall the Lexmark software properly by clicking on the Windows logo Start menu > All Programs > Lexmark Series folder > Tools > Uninstall. Then, restart pc. I suggest you install the updated driver available for download in the Lexmark website (I assume you have the Lexmark X7170 and your computer's running on Windows XP). Just click on this link: http://bit.ly/dxFJ36. Download the software. When installing, just to make sure, disable any firewall and your anti-virus temporarily. For the fax and the scan software, you can use the installation cd to install them back. Leave a comment if you need more assistance. Thanks.
May 12, 2010 | Lexmark X7170 All-In-One InkJet Printer
My scan button does nothing. How can I scan?
When you press the "scan" button on the lexmark, the scanner is trying to connect to a specific software program that in this case you may not have installed.
You will want to try to test the scanner driver directly.
For windows XP and Vista, try the following.
1. Open your start menu
2. Select Control Panel
3. Select "scanners and cameras"
NOTE: for windows Vista, make sure you are in "classic view" to see scanners and cameras.
4. Check whether there is the lexmark listed in this window.
For windows 7, you will need to do something a little different.
2. go to All programs
3. Open "windows Fax and scan"
4. Click on "new scan".
5. Check whether there is the lexmark listed in this window.
If there is no lexmark, you need to check the lexmark website for drivers. If the lexmark is there, try double clicking the icon to run the scan wizard.
Thanks,
Pat
Mar 31, 2010 | Lexmark X2330 Printer
I can print from both of my computers using the
the vista is so slow.....
plz use the xp , put the paper in the scanner place , and then press in the scan key in the printer .
if it isnt work plz install the program from the given cd and then try scanning through it.
Jan 25, 2010 | Lexmark P4350 All-In-One InkJet Printer
Lexmark x3550 will not scan 'Downloading Application List" and "
Had the same problem. Installed the most recent drivers. OK now. Good luck. - Kakou
Feb 05, 2009 | Lexmark X3550 All-In-One Printer
Lexmark 2500 Series printer does not work properly.
my printer does not print, but tells me i have prints pending
Sep 13, 2008 | Lexmark X2500 All-In-One Printer
My printer won't work and I'll need to use it soon!!
Go to Lexmark.com and check on a vista update, most of the older software simply does not work with vista.
Aug 11, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark Printer Install - No Communication Error
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark 2500 Scanning
my lexmark 2500 scan wont work I get App4r exe problem...
Sep 04, 2007 | Lexmark All-in-One Printer with PictBridge
Lexmark All-in-One Printer with PictBridge Logo
386 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
