Question about Sanyo PLC-XT25L LCD Projector
Sanyo Multimedia Projector PLC-XT25L
My projection is coming out on the right side of the screen. What can I do?
  • 2,071 Answers
You need a service menu code to adjust the screen,Hold down the Menu and Normal Buttons and watch the screen . I believe the fine sync= and - buttons move the data window Up and down and the volume + and - change the
Value. the 11 12 and 13 numbers control the screen adjusment. MAKE SURE YOU WRITE down the values before you change anything!! .
the 37 window tell you the Hours to replace Lamp Light comes on, it counts down from 1900
Posted on Jul 18, 2008
  • 52 Answers
Hi, actually, can u pls, tell me , wat exactely its happening, and in general, try these steps,
If the is out of focus, then,
try to adjust the lens of the projector and see that u Provide proper distance between the projector and projection screen
And also, Check the projection lens to see if it needs cleaning.
And Moving the projector from a cool to warm place may result in moisture condensation on the projection lens. In such cases, leave the projector off and wait until condensation evaporates.
OR if Image is Left/Right reversed or Top/Bottom reversed, then,
Check the Ceiling/Rear function.
ie, in Ceiling function, When this function is set to “On,” the picture is top/bottom and left/right reversed.
But, if the above is not correct, pls tell me some more details about ur problem,
Thank u
  • 2,323 Answers
Click here to download the user's manual. Go to page # 50 if you are seeing the image on the right side of the screen.
How do i eliminate the vertical green lines on the projected area?
Sadly the LCD/DLP wafer is failing, and the problem will progressively get worse. The DLP wafers can be replaced but it may cost as much as replacing the entire projector with an updated one. SORRY!
May 26, 2014 | Sanyo PLC SU20N Multimedia Projector
How to fix shadow (stain) projected onto screen by projector Sanyo PLC-SW30
This could be showing the signs of the lamp needing replacement. if not dust has accumulated (clean filters) onto the mirrors in the projector.
May 15, 2010 | Sanyo PLC-SW30 Multimedia Projector
My sanyo projector is projecting everything in red and the replace lamp light has come on, I have replaced lamp but it is still red.
It was a computer cable problem. One of the pins in the cable had been snapped and this has now been replaced.
Nov 03, 2009 | Sanyo PLC-XU56 Multimedia Projector
Can't get power point to project on sanyo pro xtrax
sounds like it could be a problem with the output resolution of the computer. some projectors will not be able to display anything higher than 800x600, and most computers now can output at a higher resolutions. check the limits of the projector and change the the display on the computer by right clicking on your desktop and going to properties >settings >screen resolution.
Oct 13, 2009 | Sanyo PLC XU35 Multimedia Projector
Can not make picture bigger on my Sanyo PLC-SW20 projector
depending on the size of the surface you are projecting on, and what the zoom capacity of your lens is, you probably only have one choice available to you, and that is to move your projector farther away from what you are trying to project onto.....
hope this helps!
Jan 10, 2009 | Sanyo PLC-SW30 Multimedia Projector
Projection issue
sounds like you might need to change the KEYSTONE settings
Nov 14, 2008 | Sanyo PLC XU35 Multimedia Projector
Yellow band on the edge of screen
Hi chucri
This is most definitely not a lamp problem.
If a yellow colour in either stripes or blotches occur it is a blue LCD polarizer that needs replacement.
May 16, 2008 | Sanyo PLC-SP20N Multimedia Projector
USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Jan 17, 2008 | Sanyo PLC-XU73 Multimedia Projector
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Sanyo PLC-XT25L LCD Projector Logo
151 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
