Hello and thanks for inquiring. Take the front covers off the inside unit. This is where you will find the Gas Valve. Next locate the pilot assembly. This can be done by following the thermocouple from the gas valve to the end where you will see a little v shaped piece. This is where the gas will come out. Turn the Gas Valve selector to PILOT. Depress the gas valve and use a match to light the pilot. Hold the valve down for 30 seconds. Then let up and to the gas valve to the ON position. The unit will come on and light and when the bonnet temperature reaches 180 degrees the fan will kick on. Hope this helps you.
Testimonial: "Thanks! I actually figured this out on my own, but your solution is right on the money."
