Question about IBM (25P3294) Motherboard
IBM Power Hi.  I am not able to get any power to my IBM with the cord plugged in.  The battery has now drained and will not charge.  When I plug in the power cord it does not register as plugged in....still shows the laptop using battery power.  This is a 4 year old IBM, is it fixable or worth fixing?  Also do you think I can retrieve my data from the PC? Thank you for your expert advise!
  • 55 Answers
You can experience the following problems.
1. Your power supply is bad or connector on your power supply is broken. Check output voltage on your connector with multimeter.
2. The connector on your laptop is bad. Requires disassembling of your laptop. Depends on the model it could be outside the board or soldered to the board. In any case it requires special skill's to do it.
3. The system board on your laptop is bad. Requires repair or replacement of the board.
I would charge at least $100 to replace your system board or connector on the board. All parts are extra.
Good luck
Posted on Jul 25, 2008
  • 781 Answers
Check the wall plug for power
I have had one where you had to wriggle power fitting in computer (bad plug)
Lap tops are getting cheaper so it could be a viable proposition to upgrade
Any competent local computer shop could transfer files from old computer to new
you could make it a condition of sale
Can't identify power source warning
Your AC Adapter Power Cord is bad based on what you are telling in your request for help. You need to replace the AC Adapter Power Cord.
You can further isolate and verify by the following steps:
If you remove the battery, and plug in the power cord, but the computer will not boot up or work, then the power cord is bad.
If you have them both plugged in and you are running off the battery then the power cord is bad and it is not charging the battery. Eventually your laptop is not going to power on because the battery will be drained and cannot be recharged until you get a working Power Cord.
May 15, 2012 | Computers & Internet
Gateway MS2291 wont power up
Did you check the DC Jack where the Power Cord plugs into the laptop? If it is bad (wiggly or loose) then the laptop will not power on. Take an ink pen and put it where the power cord would plug into the laptop and see if the jack wiggles or is broken. If so, that's your problem.
The old power cord might be some good if the problem is with the DC Power Jack.
May 01, 2012 | Gateway Computers & Internet
Why is my acer emachine charging blinks in red
That is a signal that your battery is almost dead or drained. If you have the power cord plugged in and the battery is not charging at all, that means the battery is dead and you need to purchase another one.
In windows xp you should be able to click Start/Control Panel/Power Options. When the power options window opens click the Power Meter tab. It will tell you if your battery is charging.
Now to isolate if it's really the battery that's dead or if it's the Power Cord that's bad. You might really be operating on battery power even though you have the power cord plugged in.
1) Turn the laptop off and remove the battery. Turn it back on with only the power cord plugged in. If it comes and and boots up ok, then your power cord is ok.
2) Turn the laptop off and this time put the battery in, but leave the power cord off. Now hit the power button and see if it boots up. If it does that means you might have a little power still left in the battery, but since it was not charging when the power cord was plugged in, the battery is bad because you verified in step one that the power cord is good.
Mar 21, 2012 | Computers & Internet
Hi, how to resolve ibm thinkpad t43p on startup with black screen
It could be a faulty battery. Remove the battery & try to power up the laptop.
If the laptop did not power up after removing the battery, then notice the power receptacle where you plug the power adapter's cord to the laptop. While plugging the power cord in, notice if there is a spark occurring at the power receptacle. If the spark occurs, then disconnect internal drives & connectors one at a time until subsystem with short is identified. If power input still a short with bare motherboard, replace the motherboard. If the spark did not occur, then inspect the boards for burnt or melted components, cold solder on DC jack, open connections, or unseated cards.
Feb 10, 2011 | IBM ThinkPad T43 Notebook
My battery is not charging. The charge light keeps flickering orange once i plug in the charger but it never charges. The computer switvhes of the moment i unplug the computer. what can i do?
Try to perform power drain first. Please follow procedure below.
Take out the battery
Unplugged the power adapter
Press and hold the power button for 30secs
Put the battery back in
Plugged in the power adapter
Turn ON the computer
If same issue will happen after this troubleshooting. I suggest you purchase a new battery. If you unit is still under warranty, you may call IBM tech support for battery replacement.
May 31, 2010 | IBM ThinkPad T23 Notebook
With power cord plugged in and without power cord plugged in the pc will not turn on
remove the battery, plug-in power cord then power on. your battery may be completely drain and your power adapter can't give enough supply to power up your laptop and charge the battery at same time. if doing so power on your laptop, charge your battery for about 12 hours without turning the power of your laptop
Nov 03, 2009 | ASUS EEEPC901-GP010X Netbook
IBM Thinkpad R40 power problem
This sounds like a power cord or connector problem.
these cords offten break at the back of the connector to the lap top. When you hold it just right it will work. Otherwise it acts up.
If the battery were in good shap it would smooth out the issue but....
Replacment power cord/transfomers are reasonable on e-bay many come out of china and are inexpensive. also consider an all in one type that will be upgradeable for your nest notebook and work in the car or airplane as well as the house. I like Igo brand and Targus but they are a personal preferance.
bg
Nov 25, 2008 | IBM ThinkPad R40 2722 Notebook
Battery indicator flashes even when plugged in to electrical plug, computer recognizes plug-in. Computer will not run with power cord.
The battery indicator flashing when plugged in to electrical plug means your battery is completely dead and won't charge. You're computer should run with just the power cord. Your power cord most likely needs replacement.
If you know anyone with the same model of laptop ask if you can borrow their power cord and/or battery to test it out. It is rare for the problem to be the motherboard, though it does happen.
It may just be the power cord at fault as the computer should run without the battery, so you should replace the power cord, as it is probably the reason the battery is completely dead.
If the battery is at least a year old I would replace it since they generally don't last too much longer than a year.
Sep 09, 2008 | IBM ThinkPad T40 2373 Notebook
IBM (25P3294) Motherboard Logo
89 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
